3.4 intake swap on 3.1 engine
i was reading and searching for mods and info to get some more horses with out spending a crazy budget,anyone had done this swap??anyone know the budget range and problems i compare a 3.4 alero from my friend and even the egr seems to be in a correct place,i did notice coolant lines may vary as they run from the coolant reserve towards the thermostat side of the water hose.any help will b appreciated
Have you thought about swapping a 3.8+trans+axles instead? Maybe even a supercharged one? Monte Carlo's came with 3.8 in 99. You would need the engine, trans, axles, PCM, wiring, maybe radiator, alt, starter, and a few more things you could get from the donor car. Worth taking a look!
Originally Posted by montyss02
(Post 205126)
