03 ls single to dual exhaust???
Old Feb 25, 2011 | 09:13 PM
monte003's Avatar
Question 03 ls single to dual exhaust???
I am going to convert my car from single to dual exhaust this spring and i want to delete my resinator and CAT any have any suggestions
Old Feb 25, 2011 | 09:41 PM
Single to dual exhaust ? are you talking a true dual or single going to two mufflers ?
Old Feb 26, 2011 | 02:16 AM
true dual basically isnt going to happen. youll need a ypipe and 2 mufflers and tips
Old Feb 26, 2011 | 08:36 AM
Just need to install a hanger on the driver side, and run the Y-pipe to dual like the SS
Old Feb 26, 2011 | 12:09 PM
monte003's Avatar
what are wsome good brands to run cause i want an agressive sound
Old Feb 26, 2011 | 12:31 PM
zipper's Avatar
Borla is a good brand for mufflers.
If you remove the cat though, you're going to have to do something with the rear O2 sensor. ZZP has an O2 emulator, but it's kinda pricey ($60). Or you could get the PCM reflashed, but that can be a little pricey too ($125 at ZZP).
Old Feb 26, 2011 | 12:53 PM
monte003's Avatar
is anyone against me keeping the cat and resonator
Old Feb 26, 2011 | 02:08 PM
depending on state inspection requirements, you may have to have a cat to pass emissions inspection!
Old Feb 26, 2011 | 02:32 PM
zipper's Avatar
You can do whatever you like to your Monte. That's your choice. I just wanted to let you know what all was involved in removing the cat. On the other hand, you can remove the res without any worry of tuning or anything.
Also, Michigan has no inspections.
Old Feb 26, 2011 | 05:27 PM
Jordanshedd5's Avatar
Not trying to thread jack, but im planning on doing the same thing. I think i remembered reading this somewhere...
Does removing the u-bend and resonator decrease back pressure?
Does that mean less low end torque?
Is it a noticeable loss?
