Steering Wheel Control Wire Harness
Old Sep 17, 2013 | 09:33 AM
silveradoman298's Avatar
Default Steering Wheel Control Wire Harness
I want to add radio controls to the steering wheel of my 2003 monte carlo ls. I pulled apart the steering wheel only to find there is no connections to add steering wheel radio controls. Does anyone have any thoughts?
Old Sep 17, 2013 | 12:41 PM
I have not researched doing this mod, but I suspect you may need a different clock spring (used with things like the air bag connections) and the wiring harness that connects the button together to a connection behind the air bag (that I suspect is from the clock spring).
Not sure if anyone here has done this upgrade, if so, hopefully someone with experience can chime in.
Old Sep 17, 2013 | 12:47 PM
lilmonteZ34's Avatar
Old Sep 17, 2013 | 12:59 PM
Wrong item. The OP is not adding an aftermarket radio and wanting to keep the wheel controls functional. They are just trying to add a factory option of radio controls they currently don't have.
Old Sep 17, 2013 | 02:50 PM
Default Steering Wheel Radio Control Clockspring
So, my next question then would be, could I swap the clock spring with one out of a model that does have the oem Steering Wheel Radio Controls, or is it as simple as getting a different harness that clips to all four buttons and joins them into the clock spring harness? Also, if it is as simple as swapping the clock spring, would the rest of the wires that run to the head unit need to be swapped too. I haven't pulled apart the dash to see if there is a data wire that runs from the clock spring to the radio. I would think if its there, then all I need is a different clock spring that utilizes that data wire. I would attempt this add on if the rest of the wiring is there. I would find it hard to believe gm would use different interior wire looms for different trim levels.
Old Sep 17, 2013 | 05:03 PM
You have to unplug the main plug that the cruise hooks up to.
an plug the main plug that has the radio & cruise wires..
Here's a pic.. I have a set of buttons with the wire for sale $50 shipped in USA
<!-- / message -->
<!-- sig --> __________________
Old Sep 17, 2013 | 07:10 PM
So it is just plug and play then? I couldn't understand why it wouldn't be. Unfortunately the buttons I purchased didn't come with the wire harness. Any thoughts on a oem part # or where I can get them?
Old Sep 21, 2013 | 12:29 PM
Default Steering Wheel Controls Harness
Thanks zjerry for explaining this and providing the diagram. Im heading to a couple junkyards tomarrow to try and find this wire harness. I presume any monte carlo between 01-05 should have the same harness. If I have no luck, would a harness out of an impala steering wheel work just the same?
Old Sep 21, 2013 | 09:07 PM
Any '00-'05 Monte harness will work.
I do not believe an Impala harness will work (or I wouldn't take the gamble on it if it were me).
Old Sep 22, 2013 | 03:14 PM
I went to a few junkyards today. No montes. Lots of impalas but the harness is slightly different. I checkout gm parts direct and they have part no. 12450138 available, although it is described as w/o cruise.
