Your opinions
Old Jul 16, 2025 | 06:37 PM
Jim L's Avatar
Default Your opinions
Ok. Went for a cruise in my 85 SS the other day. I drive it easy. Don’t want to break anything. For some reason it started smoking blue smoke from both tailpipes. It has true duel exhaust so it’s from both banks of cylinders. Parked it. Went for an extended cruise tonight to see if I could duplicate what had happened previously. Nope. Runs perfect . No smoking whatsoever. Any thoughts would be greatly appreciated.
Old Jul 17, 2025 | 06:59 AM
Blue Smoke is usually a sign of a Oil leak into the cylinders sometimes happens when the oil that is in the Heads bypasses the valve and gets into the cylinder. Could be that the seal on the top of the valve at the rocker is weak.
This could happen on both sides as well. I have seen Mechanics take the valve cover off and run the engine to see which one is the issue. But I wouldn't do anymore.
Might just need some good Lucas oil additive to help those seals. Try that on the next oil change.
Old Jul 26, 2025 | 07:08 PM
Jim L's Avatar
Default Thanks
Thanks for the info. Greatly appreciated!
Old Jul 28, 2025 | 07:29 AM
zucchi's Avatar
It could also be the PCV valve.
Remove each spark plug then examine for fouling to see if it's across the board.
Old Aug 2, 2025 | 05:48 PM
KCC11's Avatar
Check not only the pcv but the breather side of the pcv. Too much vacuum inside the motor and it will pull oil pass the weak valve seals. ( It's a 1985 so the seals are going to be weak).
12cemudd
Mar 27, 2015 12:42 PM
Murray137
Oct 1, 2013 12:17 PM
06mistreSS
Aug 21, 2012 03:04 PM
minimoto004
Dec 19, 2009 06:39 AM
domawi84
Apr 4, 2008 07:30 PM
