Your Monte -> Please Click, & Post
Old Dec 15, 2008 | 06:57 AM
Default Your Monte -> Please Click, & Post
[align=center]Hi Members[/align][align=center][/align][align=center]Please post[/align][align=center][:-][/align][align=center]1. Year/model/engine of your Monte[/align][align=center][/align][align=center]2. TotalMiles ?[/align][align=center][/align][align=center]3. How many owners?[/align][align=center][/align][align=center]4. What Modifications ?[/align][align=center][/align][align=center]5. What problems have you had?[/align][align=center][/align][align=center]6. Estimatedcost for above repairs ?[/align][align=center]
[hr]
[/align][align=center]Thanks in advance for your post/time.[/align][align=center]I hope your posted information helps other[/align][align=center]members & pinpoints expected problems.[/align][align=center][/align][align=center]* Please don`t highjack with other topic`s, thanks[/align][align=center][/align]
Old Dec 15, 2008 | 07:02 AM
Default RE: Your Monte ?
[align=center]Example post answers[/align][align=center][/align][align=center]2006 Monte Carlo LT3, 3.9L 242 HP[/align][align=center]32 K miles[/align][align=center]2- Owners[/align][align=center]K&N Panel Filter[/align][align=center]Headlight covers replaced under warranty[/align][align=center]Remote start reprogramed[/align][align=center]MPG 23 city 30+Hwy[/align][align=center]Mobil 1 every 5K - Sunoco/Shell fuel[/align][align=center]No other problems : ) [/align][align=center][/align]
Old Dec 15, 2008 | 08:43 AM
jeff2425's Avatar
I have an 02 monte ls in competition yellow. I am the second owner bought in jan. 06 with 50,000 miles now has 79,000. until this year no problems. march 08 approx. 67,000replaced right front hub thru a bud that is a gm tech. cost $300. still has intrmittent problems with trac control activating at slow speeds and wheel turned sharply. at 70,000 same bud replaced the cursed intake gaskets and also all the lifters. had 2 or 3 ticking like a rod bearing was going out so I got lucky it was just lifters. cost $500. my bud said that would have been about $1400. if I had to go thru gm.06-08 key cyl. locked up and had to get my car towed home. replaced cyl. and passlock $200.just 2 weeks ago my driver seat heat element quit and still trying to save up to fix that. looks like $400. if I go thru gmpartsdirect.com and then to interior shop.I know it sounds like a bad year but I still love my banana. I have been dreaming of a sudden winfall of $$$$$$$ to buy an 07 laser blue SS with low miles but no luck so far.
Old Dec 15, 2008 | 09:04 AM
[align=center][/align][align=center]Hi `Jeff,[/align][align=center]Thanks for taking the time to share/post your information.[/align][align=center]Sorry 2 read that you had a few problems, but happy to read[/align][align=center]that you still love your awesome Monte Carlo.[/align][align=center][/align][align=center]I am hoping this thread topic indicates the few problems[/align][align=center]encountered with owning the awesome Monte Carlo, and what the[/align][align=center]estimated- $ cost $ would be to repair.[/align][align=center][/align][align=center]"Love your Monte & your Monte will Love you ~ Abuse[/align][align=center]your Monte & your Monte will abuse you"[/align][align=center]~ For the Love of the Monte Carlo ~[/align][align=center][/align][align=center]OK Members, your turn 2 post [/align][align=center][:-][/align]
Old Dec 15, 2008 | 08:38 PM
Blown04SS's Avatar
2004 Monte CarloSS, 3.8L Supercharged 240ish HP
53K miles
2 owners including me
cat-back with magnaflow mufflers
no problems yet
havent even had the change the oil yet...i just bought her in october
Old Dec 15, 2008 | 09:08 PM
2000_BLACK_SS's Avatar
2000Black Monte Carlo SS 3800 series 2 engine 200 base HP 225 base Tq.
74xxx miles
3rd owner bought off ebay in the winter of 05 for $9500
Performance-Custom CAI, TB spacer, ZZp HV3 intake insert, Custom P&P lower intake manifold, ZZp front powerlog ceramic coated, ceramic coated crossover pipe, TB heat shield, Random Tech 2.5 downpipe and ubend delete, high flow cat, O2 simulator, Borla Cat-back, 180 T-stat. Royal purple since 55xxx miles.
Apperance- 5% tint on back 3 windows, Black headlights & clear corners, LED taillights black, 51-Fifty 705B rims, painted calipers, custom interior accent pieces, LED accent lighting. Custom painted engine bay,
Suspension/Brakes- GMPP rear trailing arms, Intense racing upper motor mounts, cross drilled and slotted rotors, ceramic pads, Falken FK452 rubber.
Lights-6000K HID low beam headlights, 8000K high beam headlights, stealth turn signal bulbs.
Stereo- Alpine head unit, Rockford Fosgate p6002 amp,2 Alpine type R 12" Subs, Rockford Fosgate wiring, generic box.
only problem i have had happened this summer with the front right wheel bearing started grinding. probably will cost me about 120 to replace both the left and right side at the same time and then another 80 bucks to get it alligned.
Old Dec 15, 2008 | 09:25 PM
RickCoMatic's Avatar
2004
Monte
LS
3.4 Stock
80,200 Miles
2nd Owner
Mods:
Vinyl Top, Chrome Bow-Tie Exhaust Tip, Fog Lights
Problems:
Turn Signal - Headlight Dimmer Switch / Failed. Replaced under Extended Warranty $790 Pts & Labor.
Cruise Control Module / Failed / Dangerous condition resulted. Car would accelerate & Cruise Control NOT Disengage. Switching Off Ignition Necessary. Problem duplicated by Service Mgr during test. Replaced by Chevy No Charge.
No other problems.
Recent Maint Expense:
Tires - $625.00
Oil-Filters- $35.00 @ Pop
CabAir Filter, Intake Air Filter, PCV, Brake Fluid Flush, PwrSteer Fluid Change, Plugs, Wires, New Oil Drain Plug: $350~400.00 No Labor / D-I-Y
No Problems
No Codes Pending
Issued Case Number for DexCool by GM Customer Svc.
Old Dec 15, 2008 | 09:51 PM
inssanity21's Avatar
06 monte ss
40000 miles on two owners
no problems yet. the remote starter sucks tho
mpg average:18 city 16 highway 28
mods: k&n cai, diablo tuner, eibach pro kit, magnaflow exhaust, and some nice visual and sound effects
Old Dec 15, 2008 | 10:11 PM
zzapultimate's Avatar
1999 Monte Carlo LS
3.1 Stock with 167k
Owners?- bought it used with 165k in September
20%tints
Vinyl Window banner
Exhaust tip
New tires at 165K
Custom accent trim pieces in interior
Accent interior LED's
JVC Headunit
2 12' alpine type e's
No problems in the 4 months I've had it.
Old Dec 15, 2008 | 10:51 PM
jaws2008's Avatar
GOT SPL
2003 SS NA 3.8L
92???
i am the 3rd owner, i bought in aug of 2008
I have a Alpine CDA 9886 with A Alpine ADX1.000 and a Alpine VPower F300 powering Alpine type R 6.5 and JL Audio TR 6x9 and A Type X 12in sub. I have 20%tint in rear sections and 35%in front widows with a tint strip across the top windshield. 18in Motegi MR7 Racing wheels on Handcook tires. Magnaflow 3.5in tips. Replaced all interior lights with blue lights instead of stock yellow. replaced headlights with 8500Klights high and low. custom Amp rack and sub box all hooked up with JL Audio wiring.
bad o2 sensor and bad cat, both replaced under warranty. dead battery 1st night i brought it home. lol.
was still under warranty.
