what oil do you use?
Old Dec 26, 2012 | 05:27 PM
tps221's Avatar
my mechanic uses kendall oil 5W-30 of course but when she gets low kendall is hard to find so i will usually mix brands
Old Dec 27, 2012 | 01:40 AM
mdominick1025's Avatar
I currently use 15-40 rotella. I might change it up.
Old Dec 27, 2012 | 05:29 AM
I only ever use synthetic. The BudChev gets Mobil 1 cuz that's what it always has. They are all good brands, but I never change brands because I am convinced that engine seals become conditioned to the additive package of any given oil. its this changing of oil types that modifies seals and causes the leaks, especial in older dirty engines. When those deposits get cleaned up, the leaking may begin.
When I was a kid, back in my lube shop days, I had an '83 Firebird (crappy 2.8 carb engine) that I was convinced leaked oil. I had to add a quart about once a month. But I was using cheap genetic any oil. I started at the lube shop and switched to Quaker State synthetic and that car never used a drop of oil again! A huge change in oil consumption. I thought the car was leaking it, but it was obviously burning it.
Synthetic oil is not some crazy foreign substance from another planet. It is merely more refined and only the best parts of regular mineral oil
Old Dec 27, 2012 | 06:44 AM
I only use Mobil 1 synthetic
Old Dec 27, 2012 | 07:56 AM
Zen's Avatar
Zen
Originally Posted by Taz
I've been using Castrol full synthetic for the last 2-3 years. First thing I noticed was that the engine ran smoother compared to regular oil.
I've always like the castrol syn we used it in Jess's car for years.
That rotella is good stuff There's additives in there that are ment for diesels but help out a lot on gas engines I'd keep using that for now.
Old Jan 3, 2013 | 12:10 PM
DixieMonteCarloDepot's Avatar
Nomatter what oil you use make sure it either has ZDDP(zinc) or buy an additive like the GM EOS, it will keep the cam healthy, Rotella T used to have alot of zinc in it but the emissions standards on diesels made them change the formula.
Old Jan 4, 2013 | 06:36 AM
Zen's Avatar
Zen
I didn't know they changed it.I used to use it a lot when I first had my monte always liked it.
Old Jan 4, 2013 | 06:50 AM
03SSLE's Avatar
Valvoline SynPower 5-30
Backed by a 300K mile engine warranty.
Old Jan 4, 2013 | 08:30 AM
Zen's Avatar
Zen
Has any one every used that warranty.I always wondered if they follow through on it.
Old Jan 4, 2013 | 08:55 AM
You have to have a lot of documentation, and start using it early in the engine's life. Also, if anything happened to the engine, it would have to be proven to be oil related damage.
I wanted to try getting on one of those warranties but the Monte always had too many miles to start.
