What do you think of it ? 86 SuperCharged 383 SS ?
-repost from MCF Blog-
86 SS SuperCharged "383"
on Ebay
What do you think a good bid would be ? ?
Post what U think of it `ok...thanks
on Ebay
Up for auction is a very unique 1986 Chevy Monte Carlo SS. I am selling this for a friend of mine. The drive train has been completely redone. I will list some of the modifications below. It is supercharged, and very fast. The condition of the car is good. There are a few bumps, and dings in it as you can see from the pictures but nothing major. The interior is clean, and has very low wear for the year. It has a CD player that you can see in the pics. Also 5 point harness for the seat belts. The windows do work, but could stand new motors. Since this car has been built for performance most of the factory gauges do not work. (speedometer, oil pressure ect.) These have all been replaced with excellent aftermarket gauges. Along with a boost gauge. Since the speedometer dosent work the actual mileage is unknown. The engine, transmission, and rear end have been replaced in the last 2 years. The car is not driven daily, but can be. An approx estimate on the mileage would be somewhere between 18-22,000 on the drive train. Once again the mileage is approximate. The car dosent get driven daily. Maybe a few times a week. This is a great looking, and running car. If you know what your looking for you already know what this thing can do. This car pulls low 8's in the 1/8th mile, but it also mild enough to drive to work everyday. It always fires right up, and runs great. I will start listing the mods below. This is where we separate the men from the boys:
ENGINE:
4 bolt main block 010 casting bored .30 over
speed pro ultra lite flat top racing pistons
speed pro .005 file fit rings
Luvti 6.0 connecting rods for stroker motors
Eagle forged crank
Cevelite bearings (rods, and mains)
High volume oil pump
Moroso oil pump shaft
7 qt Oil Pan with tray
Comp Cam Hyd. flat tapped lifters
Comp Cam 1.7 roller rockers
Comp Cam push rods
Comp Cam Camshaft
Comp Cam plate lock
World Parts S/R Cylinder Head Ported and Polished
Edelbrock Performer RPM Intake Manifold
AEP 750 CFM Carb for Forced Induction Motors
Vortec box for Carb
Paxton Pro Supercharger Centrifugal Supercharger Belt Driven
MSD Billet Distributor with MSD Wires
Holley Blue Race Pump with Regulator
Flexolite Temp Control Electric Fans
HD Radiator & Water Pump
Aluminum Polished Center Bolt Valve Covers
HD Starter
SFI Flexplate
Eagle forged crank
Comp Cam push rods
Comp Cam Camshaft
Comp Cam plate lock
Vortec box for Carb
HD Starter
SFI Flexplate
TRANSMISSION:
Turbo 350 with Shift Kit
3200-3800 Stall Race Converter for NOS & Blower
B & M Ratchet Shifter
REAR END:
Chevy 10 Bolt
3:73 Gears
Auburn Locker
Lakewood Traction Bars
3:73 Gears
Auburn Locker
I wouldn't say the car itself is plain jane. After all, it does have that big scoop on the hood.
But I agree it needs a paint job. I don't care if it's a drag racing car or not. I want my car to look bad *** going down the track. That car needs to look as bad *** as it performs. Not primer grey.
2 connect 2 Ebay ad
