Voltage drops when running A/C
Old Jul 2, 2012 | 07:52 PM
NovaSS369's Avatar
Default Voltage drops when running A/C
Hey guys, long time since I have been on here with the new job, school, etc...anyways I have a new question for everyone here....
I have noticed this for awhile but been too lazy to do anything about but here goes: when I run my a/c I can see my voltage dropping periodically from like 13.5 volts where it supposed to be down below half on the gauge. It never goes down to like 8 or anything ridiculous but if I am running my amp it does it even more. Before the amp it still did this so I know that is not the culprit. I have a 2 farad cap on my mtx amp running around 500w RMS btw. Is this a ground issue? I replaced them ground wiring on the chassis and transmission with 4 gauge about a year ago and had a bunch of electrical issues after doing it due to a lack of contact :/ what should I do here to fix this?
Old Jul 2, 2012 | 08:01 PM
nitehawkjcb's Avatar
Eh... Check your fuses first of all. Also, your alternator and/or battery could be starting to go bad.
Old Jul 2, 2012 | 08:17 PM
03SSLE's Avatar
I'd start with having the battery and alternator checked to make sure they are in good condition. Also check/clean ground connections from engine to frame and frame to battery. While you're at it check/clean the battery terminals also. I realize you said it did it before installing the amp, but did you upgrade the supply wire from the alternator to battery? I put an (amateur) radio in my Blazer and experienced a voltage/amperage drop every time I keyed the microphone. Replacing the supply wire with a heavier gauge over the factory one solved the problem for me. Check voltage/amperage output at the alternator and at the battery with engine idling and all accessories on. If you see significant difference between the two upgrade the supply wire.
Old Jul 2, 2012 | 08:52 PM
NovaSS369's Avatar
I need to upgrade the supply wire definitely. I put in a new battery & alternator last year at the same time so I doubt those are the issues. I will clean everything up - terminals, grounds and add supply wire - hopefully tomorrow, and post the results.
Old Jul 2, 2012 | 08:53 PM
monte07's Avatar
i would use a volt meter after you get your battery checked. what i mean is it soulds like a voltage regulator is going bad in the alt or the battery is going bad. but i do have a question do you have capasitors for your stereo system? because it will also put a hamper on the charging system. but first thing first check the battery and the altinator. the battery should be the first. then the altinator.
Old Jul 2, 2012 | 08:59 PM
NovaSS369's Avatar
the cap is irrelevant really because it was only installed last week on my amplifier and before the amp was even installed it would do this.
Old Jul 3, 2012 | 08:16 AM
Just because a battery/alternator is new doesn't mean it's not the culprit. I would still get them tested.
Old Jul 3, 2012 | 11:41 AM
I have 2 MTX amps....4700 thunder and a 500 D...
Check both grounds from the amps to frame....
And be sure you have the correct Wireing it all together!
Also dbl ck the "inline" fuse..
(Did you instahl it yourself?
Also I had to go to a Heavy duty alternator....I also have a "Inline" power switch. (to turn amps off when not in use like parked over night to not drain the battery) along with a in dial that controls..how many watts I preferr to use...(Dial up or down the subs)
check my garage for my amps subs etc...
Youll also notice my amps are mounted on the sub box as well...
My system was instahled by MTX...Techs...
Old Jul 23, 2012 | 10:37 PM
Dee Gee's Avatar
Unhappy New Battery and Alternator has been tested?
I have a 98 Monte and for the past month when i use my a/c the lights start to fade out and the air goes warm I have checked the fuses and all except the lighter fuse are good. Any suggestions???
Old Jul 24, 2012 | 05:55 AM
aussiek2000's Avatar
You're going to notice some voltage drop with A/C on. First the blower motor pulls 30 amps. Second, the A/C clutch pulls 10 amps. Third, the fans pull anywhere from 20-40 amps.
