Video Bypass
Old Jun 14, 2010 | 01:05 PM
theeohiostate6's Avatar
Default Video Bypass
Well i just got my new alpine ina-w900 installed a couple of days ago. the only problem was to access any settings, watch any videos ipod or dvd was that you had to have been in park then push the parking break in twice before you could do any of that. So i did a little searching and came across this device the PAC-TR7.
http://www.amazon.com/PAC-TR7-Univer.../dp/B0002J22BO
This has to be one of the easiest hook ups i have ever done. All i had to do was connect about 5 wires, a power, ground, remote turn on, foot break, and parking break. all of which wires are coming out the back of the HU. I know this module works for alpine head units and i would definitely suggest it to anyone who wants these features while driving.
Old Jun 14, 2010 | 05:14 PM
theres a code for them that allows you to watch without the parking brake
Old Jun 22, 2010 | 04:43 PM
eviling's Avatar
heh, just wire the parking break hot line to a relay connected to your ignition line or remote wire for your amps, so that when your amp remote or ignition power comes on, it powers the relay sending that constant hot signal, or a ground in some cases to the wire, and blamo, it works, you can't do this with every deck, and some require you just physicly pull the pin out of the harness and swap it to another slot, but it's incredbly simple to just use a 7$ 4 or 5 prong relay depending on how you wire it, and blamo. just need a set of crimps, and some female togle pins. as near i can tell, that unit is just a relay, in a nice little package with wires, and eveything. most likely solid state instead of a relay. but relays are more reliable if you ask me :|
Old Jun 23, 2010 | 01:01 AM
alvinbell21's Avatar
I wish alpine would have put some more things into the unit software like custom backgrounds, the ability to change the color of the hard buttons, other than that everything seems to work nice, I have noticed that the navigation seems too have a hard time changing, from night mode to day time mode color maps.
Old Jun 27, 2010 | 09:35 PM
c0dak's Avatar
Hey guys quick question, I just purchased a jenson vm9214 and I have it all wired up but where do i find the parking brake cable to hook up to it?
ZIPPY02
Jan 29, 2014 04:51 PM
HaRvArDaLe
Dec 6, 2006 02:26 PM
SirMonte34
Jul 24, 2006 03:31 PM
1fastV8
Feb 21, 2006 04:25 PM
partyboyjaw
Oct 26, 2005 11:05 PM
