Under-dash water sloshing sound. Any ideas?
Old Apr 18, 2018 | 04:48 PM
Johnsadie's Avatar
Double check your doors because it is very possible water is trapped in the door from rain falling into the outside window area. There is a seal at the bottom of the door that you can gently pull away and you’ll see the water drain Good luck.
Old Apr 24, 2018 | 09:11 PM
Robert Lang's Avatar
I too am having this problem but it only happens when its been raining. Unfortunately my car is not in a garage or covered carport due to where i live so its in all the elements of outside. Im really thinking its from the rain. But how do i get the water to come out? Someone said a door plug but where do i find it etc? I dont think its my heater core as im In FL and NEVER use my heater and it always happens after we had a hard rain. Thanks
Old Apr 25, 2018 | 08:08 AM
Open your door, on the bottom is a rubber seal, behind that is the drain plug. You can pull the rubber seal (carefully) and get easier access to the drain.
Deeana
May 22, 2017 05:01 PM
hillre48
Aug 15, 2010 08:50 PM
ltman
Nov 28, 2008 06:35 PM
ltman
Apr 11, 2008 05:48 PM
Brooke
Oct 17, 2007 04:35 PM
