um ****
GAH I HATE MY CAR SOMETIMES!!!(yes i will be venting). I tried to take the stupid pummel off and couldnt get they freaking bottom bolt figured no big deal ill take off everything connected to the pummel as well since i plan on painting that too. then*snap* the freaking bolt that connects the tb to the collant brakes of now, how the heck am i going to get that out! wth! Love the engine and hate it at the same time! only good thing i guess is i am not leaking any coolant but for how long til it starts shooting everywhere!!......i hate this love/hate relationship i have with my car......venting session over
I tried to take the stupid pummel off I tried teh googles: Elvis Pummel https://encrypted-tbn2.google.com/im...FFahvcACjanDKQ Pummel the uterus pinata https://encrypted-tbn0.google.com/im...58Z8Ks-K9NfaNM Pummel horse https://encrypted-tbn3.google.com/im...kMQxKXn0SHYXyA Pummel Pads https://encrypted-tbn1.google.com/im...CxGoeaTYAuMlyZ Inflatable pummel https://encrypted-tbn2.google.com/im...368-MlaDlrxGNb First image result Pummel.jpg https://encrypted-tbn3.google.com/im...wLZh7fkQWdUjpw Then I tried pummel car: https://encrypted-tbn1.google.com/im...jUFnWbJUiU3O1z |
(Post 461812)
What is a pummel?
When you take bolts out that connect the TB extension to the plenum, use a wrench to get it loose little by little and once its somewhat loose, use some needle nose vise crips to grab the end of the stud and turn it out. Once you have the bolts out, grind the end of the stud off down to the bolt head so its just a bolt, not a stud. Then you can use a universal joint on an extention to get the bottom bolt in and out easily. Make sure you replace the gasket between the plenum and the LIM as well as the gasket between the plenum and the TB extension. Ive had mine off a few times now and ive got it down to a science. Can remove the plenum in about 15 minutes now.
Originally Posted by mrl390
(Post 461841)
The only thing you can really do is drill out the bolt and retap it. Ive never had any luck with any of those broken bolt removal gimmick tools. Especially in aluminum. As long as its not leaking, I would just leave it for now. You may do more damage trying to get it out than you will if you just leave it alone. Drilling a steel bolt out of an aluminum piece can be tricky cause the bit wants to walk off the bolt and messes up the aluminum around it.
coo thnx
