Tires
Old Apr 7, 2008 | 10:04 PM
inssanity21's Avatar
Default Tires
i have recenlty bought a set of 19" chromes for my 06 mcss and did not buy tires. today i went a researched some tires for them. the lowest priced set i could get was 1200 bucks. now recently i bought tires for my gmc jimmy [everyday drive] they were only 85 bucks each.
is that not ridiculous. there goes a couple paychecks then another one for fuel at 3.65$
this thing is getin expensive. especially with my repaint project on it.
Old Apr 8, 2008 | 05:05 AM
Default RE: Tires
The (stock) tires for a Jimmy are not low profile. For whatever reason, tire companies charge insane amounts for low profile tires. Even though there's less rubber. Go figure.
Old Apr 8, 2008 | 05:21 AM
mrl390's Avatar
Default RE: Tires
Go to tirerack.com and check out their tires. They seem to have pretty good prices on pretty much every tire.
Old Apr 8, 2008 | 05:48 AM
rysZ34's Avatar
Default RE: Tires
Low-Pros are stupid expensive; not to mention that rubber to fit a 19" rim is still not considered "standard". Anytime you put tires on a large rim it will be expensive. Shoot, my '06 Aveo LT I used to have had 185/50/15's on it stock and only two companies made tires for it. So I put 195/60/15's on it, andthey wereGoodyear Eagle LS for almost $700.
Old Apr 8, 2008 | 06:19 PM
Default RE: Tires
i knew that they would be expensive but thats alot more thatn i thougth jeez.
but they look good!
Old Apr 8, 2008 | 06:32 PM
God_Bot's Avatar
Default RE: Tires
Wow, 1200 for tires, that's as much as the set of wheels and tire combo that I was looking at this past summer would have cost.
I plan on going up to 18's sometime, sure hope they don't end up costing me dearly in the end.
I'm curious as to what this repaint project of yours is, have any pictures?
Old Apr 8, 2008 | 06:42 PM
GrandPaDave's Avatar
Default RE: Tires
ORIGINAL: inssanity21
What aspect ratio are you looking at, 30?
I could see why they are so much.
35's are much cheaper.
http://www.1010tires.com/tire.asp?ti...remodel=FK-452
Old Apr 9, 2008 | 09:02 AM
Default RE: Tires
i am in the process of my painting. right now the car itself is apart i will get somekind of pictures up soon. and how would i put multiples of them up on this? im still new
you know alot about those tires on that link they are much cheaper than the bridgestones, dunlop, and bfgoodriches ive been looking at
Old Apr 9, 2008 | 11:09 AM
God_Bot's Avatar
Default RE: Tires
My favorite way to post pictures is to host them on imageshack.com, and then copy the direct link to image that they give you and put it inbetween image tags like so:
Code:
[img]url goes here[/img]
Old Apr 9, 2008 | 12:20 PM
Default RE: Tires
FALKENS are very good tires for the price.
