-Street Monte + More -
Old Mar 28, 2009 | 05:36 AM
  #31
Arrow Buy it from Dale : )
2007 Chevrolet Monte Carlo SS
14 Photos
Price$19,993 Miles19507 Miles VIN2G1WL16C879388015Stock4817P2007 Chevrolet Monte Carlo SS Coupe, 5.3 liter small block 303hp V8, black with black leather heated seats, sunroof, 18" polished aluminum wheels and universal home remote. These "SS" coupes are getting hard to find and if you are looking for a nice one, this is the one for you`Space More info
Just doing my part to `help the economy, & maybe help a
member find the last year 4 the AweSome Monte Carlo SS
Old Mar 28, 2009 | 05:43 AM
  #32
Cool Space Dreams : )
Another `SpaceDream
Attached Thumbnails -Street Monte + More --chevy_monte_carlo_dt_dv_05_05.jpg
Old Mar 29, 2009 | 05:03 AM
  #33
Arrow `83 Street Legal (RaceCar: )
1983 Monte Carlo Street Legal (Race Car)
Car
Ÿ Harwood Cowl Hood - on hinges
Ÿ SS Trunk Spoiler
Ÿ Champagne with dark burgundy interior
Ÿ Bench Seat with arm rest
Ÿ Power windows
Ÿ Tilt wheel - with SS wheel
Ÿ Working wipers and washers
Ÿ Heater - with non A/C box
Ÿ New manual steering box
Ÿ 5” auto meter tach with memory
Ÿ 2 5/8” Oil and Water gauges
Motor
Ÿ 350 - 30 Over - 355 cubic inches
Ÿ Forged Pistons – 101/2 to 1
Ÿ Crane Cam 502-292
Ÿ Steel LT1 Rods and Crank - Balanced Assembly
Ÿ 7 Quart Moroso - kick out sump
Ÿ High Volume Mellings Oil Pump & Shaft
Ÿ Cloyes timing Double Roller Chain
Ÿ LT1 Heads - 67cc 205-160 Stainless Valves - Heads flow at 306, Port & Polish Comp Springs , Retainers, Push Rods
Ÿ Crane Roller Rockers with 7/16 Screw in Studs
Ÿ Weian Intake - new 750 Holley with 2” Spacer
Ÿ K&N Air Filter
Ÿ GM Aluminum Raised Polished Valve Covers
Ÿ HEI Electronic Distributor with High Performance Module
Ÿ Hooker Super Comp Headers - 3” Exhaust to 2 Stage Flow Masters
Ÿ Holly fuel pump and regulator
Ÿ Sump in tank and #8 braided hose to regulator
Ÿ New 4 Core Radiator with Electric fan
Ÿ New Water pump
Ÿ New Starter
Ÿ New Alternator
Ÿ New Battery & Cables
Transmission
Ÿ 350 Turbo with TCI Valve Body
Ÿ SFI TCI Flywheel
Ÿ TCI 3500 Stall
Ÿ TCI Trans cooler with #6 Steel Braided Hose from Trans to Cooler
Ÿ B&M Shifter
Ÿ 4” Drive Shaft with heavy duty “U” Joints
Ÿ Drive Shaft Loop
Rear End
Ÿ 9” Ford - Heavy Duty Housing
Ÿ Moser axles
Ÿ ½ inch wheel studs
Ÿ 456 Gear
Ÿ Southside Control Arms
Ÿ Wildwood Drill Rotor Disk Brakes
Ÿ Moroso Springs
Ÿ 90-10 Shocks in Front, 50-50 in Rear
Ÿ Hurst Line Lock
Ÿ Pro Star Wheels, 15 x 4 new Moroso 710 x 15 in front
Ÿ Pro Star Wheels, 15 x 9 with Street Legal ET Street Wrinkle Walls, 1150 x 28 x 15 rears, 85% left on rear tires
Select a pictureSeller:mange3826( 7 ) Feedback:100 % PositiveMember:since Nov-25-06 in United States
See detailed feedback Ask seller a question
Start'in Bid is $3500
Member's ? What do you think of `it ?
I'd luv 2 drive `it & take it 4 a test run : )
Old Mar 29, 2009 | 05:24 AM
  #34
Cool Got me a New Monte Carlo : )
My Girlfriend got a me a 1987 Monte Carlo SS
  • DESCRIPTIONS:
  • Brand new 1:18 scale diecast 1987 Chevy Monte carlo SS by Welly.
  • Has steerable wheels.
  • Brand new box.
  • Rubber tires.
  • Made of diecast with some plastic parts.
  • Has plastic display stand with window box.
  • Detailed interior, exterior, engine compartment.
  • Dimensions approximatelyL-10,W-4,H-3,5 inches.
  • Meet the sellerSeller:wholesale_diecast_models( 40401) Feedback:99.6 % PositiveMember:since May-27-05 in United States
Old Mar 29, 2009 | 05:52 AM
  #35
Cool New SS `Space `Sig : ) LOL
Has any member purchased from above ?
Now, I have to work on gett'in another Real Monte SS
Pretty tight fit @ 146lbs, but I started 2 mod `it already
Last edited by Space; Mar 29, 2009 at 05:59 AM. Reason: I need 2 `Go on a `Diet : ) LOL
Old Mar 29, 2009 | 07:18 AM
  #36
Arrow SuperSweet First Gen 4-$ure
1971 Chevrolet Monte Carlo
true SS-454 car
67,450 actual original miles
Great Example of a First Gen 4-Sure
67,450 actual original miles. Tilt Wheel, Power windows, Cruise Master Speed Control. Power Disc Brakes, Four-Season Air Conditioning
Original AM factory Radio, I also added Under the dash, a very nice FM/CD player with Hand remote and new rear deck speakers Sounds real good!!
Solid classic car that runs and drives great. Original white car with Black Int.
Big Block Engine runs very strong. Factory Four Barrel kicks in Good.
Original 12 Bolt Posi with Red Posi Tag.
Starts right up every time.original owner had the engine freshen up, still has the original bore specs,Completely stock,and not a drip of oil is leaking out. What a nice sound, this motor is right on the money.
Would go anywhere without hesitation.
Recently, Well just this weekend. I drove the car to South Carolina and back, This car performed flawlessly, logging in over 500 miles with out any problems. This is an easy to drive Big Block car, Nicely Documented Vintage Muscle Car that you will love to own, and watch your investment grow as you enjoy it.
Fresh oil change before my 500 mile trip. So your good for another 2,500 miles.
Transmission is a turbo 400 and shifts perfectly, It has the electronic passing gear only for SS cars and turbo 400's, No carb linkage to mess with, nice design,and the reverse lights both work,which looks good when people are listening to your pipes
Paint has some very minor chips, the car had one repaint back in 1991. still looks very nice for old paint, and the chrome is very respectable.
Engine pad numbers, Do match the Vin Number, Shown in pictures.
Very minor Surface rust in trunk, just from moisture under mat, (shown in pics) You could hit it with a big hammer and not break thru, It also has all of the original Quarter panels and sheet metal, never be damaged or repaired.
Complete New factory ordered exhaust pipes with New Flow Masters (Shown in Picture ) the old exhaust was the 1971 factory original, Not in bad shape.
Interior is in great condition,even both console lights still work.Shifter&the rear light.
Carpet is perfect and is very clean and Dry. Headliner is perfect
All gauges work, but the clock is slow & the speed-o squeeks when its cold.
A/C works and is factory complete, could use a boost for summer.
Heater works good, and all the controls slide like they should, even the glove box light works, the factory Cruise control decided its to rare to work anymore?
Honestly, have no doc's to say this is a true SS-454 car, I looked for the build sheet with no luck, it is a 138 Vin car, and the engine Numbers match, So all I can say is Bid on it as you feel fit, It is a very nice car, and I have a clear title here in my Name. I'm Not Looking to for a outrages amount, just a good home, as she deserves that after 38 years. If you have any Questions please call me at 252-636-2327 Its safe here in my garage until you make arrangements, with no time restrictions.
$10K +
Old Mar 30, 2009 | 12:05 AM
  #37
custom95's Avatar
that first monte and 70 camaro are gorgeous!
Old Mar 30, 2009 | 03:14 AM
  #38
`Noah, I agree, they both show love/$'s/detail, just
like your AweSome 06 Monte SS & your 95 Camaro
Old Mar 30, 2009 | 03:17 AM
  #39
Arrow Production #'s/Photo's/More
Image Source: General Motors Corporation
1985 Chevrolet Monte Carlo SS
Click the Below Link
for Pictures, and links to Production #'s
http://www.productioncars.com/photo-gallery.php?make=Chevrolet&model=Monte+Carlo
Click above link
Old Mar 30, 2009 | 03:26 AM
  #40
Smile Wouldn't U rather `Drive a Chevy Monte Carlo ?
There's Plenty of Room in a Chevrolet Monte Carlo for lots of `fun 4-Sure :p Jump `in & lets go 4 a ride
1974 Chevrolet Monte Carlo
1986 Chevrolet Monte Carlo SS
I wish they still produced them 4-$ure
V8 RWD
