Strange squeaking sound...
Old Sep 6, 2009 | 11:02 AM
echoingvoid's Avatar
Default Strange squeaking sound...
I've been getting a strange squeaking sound coming from the steering column on my '06 3LT as I'm turning the wheel. It's a very obvious rubber/vinyl rubbing against plastic sound. It's been going on for about a month now.
Has anyone else had this issue? Does anyone have any suggestions? THANKS!
Old Sep 6, 2009 | 11:18 AM
06 Monte LT's Avatar
Ive had something similar with my 2LT 06. Mine was coming from the engine bay, and found out that I was out of power steering fluid.
Check that first just to double check. My soon to be father in law had the same problem too and tried the fluid.
Old Sep 6, 2009 | 01:40 PM
MonteDriver's Avatar
its probably a tie rod end or a ball join, seen that on a Pontiac recently and its annoying.
Push down hard on the car on all four corners to help diagnose but sure fire way is to get it on a lift and check them for play.
Old Sep 9, 2009 | 05:34 PM
any status on this? just curious if you were able to resolve this issue
Old Sep 9, 2009 | 06:28 PM
is it squeaking? put it in neutral and let it roll back and lightly press the brakes, should help it out
Old Sep 11, 2009 | 03:38 PM
Sorry, I haven't been able to get on the forum the last few days. The issue is still there. The sound itself is coming from the inside of the car. I can hear it and feel it in my hands. The sound is coming from between the steering wheel and column itself. Like I said, almost as if the plastics and vinyls are rubbing.
Thanks for the suggestions, I'm not sure what the hell it is. I'm afraid to just put some grease in between not knowing the outcome.
Old Sep 11, 2009 | 08:21 PM
my bad i thought you were saying from the brakes, i had 2 different things open, so ignore my last post lol that was for brakes, its probably the fluid, check it or have it checked out and replaced
Old Sep 11, 2009 | 11:06 PM
Greeny's Avatar
trewyn15, where did you get the Monte Carlo insert for the break light?
Old Sep 11, 2009 | 11:27 PM
The Popcorn King's Avatar
I'll have to look, but i think i still have some like those somewhere in my apt. They are for the 6th Gen. I know i have sold them to few members here on the board.
Old Sep 11, 2009 | 11:37 PM
i got mine off ebay for 10 bucks, ive heard jj makes some really nice ones tho too, they have it for the SS too
