6th Gen ('00-'05): Strange problem
Old Jun 23, 2023 | 11:30 PM
Wheelspin's Avatar
Default Strange problem
So I have a 2004 ss with the 3.8L non supercharged and I’m have a problem I can’t figure out, the car has around 200k miles
The problem
so last week I had noticed a problem when accelerating, the motor starts to not was to keep accelerating and the rpm’s get jumpy around 3200 and runs fine after 4200; almost like it’s stumbling or something. I’ve been trying to get it to send a code and I got one today and it was for cylinder 3 misfire the only reason that came up is because when it started I went full throttle and it gave the a flashing check engine light
(also in neutral it revs fine it’s when it’s under load it will happen)
what I’ve tried so far
The cat was slightly plugged so I believed that it was plugged enough to give me problems so it was (stolen)
just today I tried the throttle position sensor but no luck
I just replaced the coils (helped a bit) I will be doing the wires and plugs later on in the week and also look for a vacuum leak.
( replaced the fuel pump when I first got it because I had no fuel gauge)
I may try to replace the fuel filter but I don’t want to keep throwing parts that I think are going bad , j have the service records from the original owner from when it was sold this year so I’ve been going down the list of possibilities
1997Monte
Oct 13, 2014 10:44 PM
Snolan860
Mar 28, 2011 07:40 PM
MetalDragon
Oct 5, 2008 04:38 PM
MPS81
Apr 15, 2007 08:58 PM
