Revised Mod plan for N/A 3800
Old Sep 17, 2009 | 08:00 AM
No problem
And that's about how I started... CAI -> Downpipe, but then I did the remainder all at once.
Old Sep 18, 2009 | 01:54 AM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
all sounds good on this build, except i'd add one thing:
i'd get a 180 T-stat for it. 10 bucks and 10 minute install.
help keep the beast feeling cooler
Old Sep 18, 2009 | 01:58 AM
Frosty LS1's Avatar
You're right! I have that on my list in Microsoft Word, but not on here. Thanks for reminding me. I'd read that with all these supporting mods a 180*T-stat can add as much as 3WHP! EVERY HP COUNTS!
Old Sep 18, 2009 | 02:04 AM
Photobucket
while it might give u that, its just important that your car is running as efficient and as cool as possible. always helps.
Old Sep 18, 2009 | 02:06 AM
Photobucket
sorry, shoulda said this in the last post, but if your going for longevity, stay away from the shift kits, especially if your planning on doing a canned pcm. i've read and heard that they dont neccessarily go hand in hand. do one or the other, but not both. personally, i'd stick with just the pcm (basically gives you all the benefits you'll see from the shift kit anyways)
Old Sep 18, 2009 | 02:09 AM
Frosty LS1's Avatar
So even a mechanical shift kit with spacers is bad? When I get my car custom tuned I can keep the shift line pressure increase out, or I can specially order it from ZZP that way, but if you think it's really going to hurt the tranny I'll stay away from it, that'll be over $50 saved right there.
Old Sep 18, 2009 | 08:19 AM
I said no to the shift kit a long time ago but you argued me
Old Sep 18, 2009 | 08:21 AM
Frosty LS1's Avatar
I did do that. But I trust in your wisdom now, so I will at the very least put the shift kit on hold and do more research/asking around before making a final decision.
Old Sep 18, 2009 | 01:29 PM
MAMONTE's Avatar
Don't do the shift kit...a custom tune will give you firmer shifts.
Old Sep 19, 2009 | 12:06 AM
Frosty LS1's Avatar
I watched your posted video like 10 times, I really like the sound of your Monte in the cabin, sounds recognizable, but you can tell that the engine is breathing better, sounds more aggressive. What do you think of CAT back exhausts? You've never suggested those. I've read up about them a little and found that the loss in low-end torque is sort of substantial, up to 10 lbs lost in the lower RPM band...although you supposedly gain that back in higher RPM's. I've read that the biggest HP boost you'll get is about 10, and that's being optimistic, but is this not suggested, not worth it?
