Oil consumption ?
Old May 19, 2016 | 08:26 PM
shawn parker's Avatar
Default Oil consumption ?
is this guy correct or full of it on the LS and oil issues ?
the review seems sorta fair, but the oil thing stood out
thanks
Old May 19, 2016 | 08:30 PM
I didn't watch the video, but LS4's are incredibly notorious for oil consumption. Most of it due to the displacement on demand/active fuel management system that shuts half the cylinders down. When it switches back and forth, often a puff of smoke comes out. Shut the system off with a tune and you're generally good to go.
Old May 19, 2016 | 09:31 PM
that is qhat he said also, he added in 3rd will override the fuel management
so sounds like he was correct
Old May 20, 2016 | 09:38 AM
Some are worse than others. My ls4 uses very little oil, but plenty of people have had the issue.
Old May 20, 2016 | 10:27 AM
Once I turned off DOD my Monte had no Oil Problems (Turned off by a tune)
Old May 20, 2016 | 08:42 PM
That's one way to do it, best way is to have it tuned out.
Old Nov 24, 2017 | 07:35 PM
skijosh's Avatar
Default Mileage w/o AFM
Whats the mileage without the AFM? If its not to bad might turn it off. To help with the oil issue.
Old Nov 26, 2017 | 04:23 PM
96z34man's Avatar
My MPG with AFM is 22. Without, it was 13. I did the math and it was cheaper to replenish the oil than to waste the gas, even if I ran 87. Also keep in mind that we have a president spoiling for a war with Iran. Gas could be $4 a gallon before you know it.
That said, to use an awful pun, your mileage will vary. Some people here don't even have a consumption issue. I know I have a reputation here for making sweeping, absolute statements, but this isn't one of those times. You literally have to track your consumption and see what makes sense for you.
