Is this an odd thing about A/c in monte
Old 06-12-2012 | 11:28 PM
16With01MonteSS's Avatar
Default Is this an odd thing about A/c in monte
My A/c has always worked until about 4 weeks ago i realized the florescent green dye was leaking from the front of the car thought nothing about it now the car only blows hot air anyone know what the problem is?
Old 06-12-2012 | 11:32 PM
I think the florescent green dye was leaking is your answer..
Old 06-12-2012 | 11:53 PM
Mike 00LS's Avatar
The fluid sounds like the oil from the A/C system. You have a major freon leak. Usually the oil that is combined with the freon doesn't leak unless all the freon is gone.
Old 06-13-2012 | 12:01 AM
You have a leak, Check where florescent green dye was leaking from ..
Old 06-13-2012 | 01:11 AM
I didnt know freon was florescent green. I was thinking an antifreeze leak
Old 06-13-2012 | 03:26 AM
I think you answered your own question...
Old 06-13-2012 | 09:43 PM
aussiek2000's Avatar
It couldn't have anything with you going 110 on the freeway and your car pulling to the right. You probably threw a rock or something through the condensor.
Old 06-13-2012 | 09:57 PM
PUNK LIFE's Avatar
if its that bright, it should be fairly easy to see if its coming from any ac components
Old 06-14-2012 | 10:35 AM
Ahh good try but pulled to the left and it was 115..
Old 06-14-2012 | 10:36 AM
Doesnt our cars use Reddex? which is red in color.
Quick Reply: Is this an odd thing about A/c in monte
