OBD2 Scanner(s) - ELM 37
Old Mar 4, 2012 | 05:27 AM
Zeke's Avatar
Default OBD2 Scanner(s) - ELM 37
I posted this as an additional reply in another thread, & got didly-squat for relipies ... so figured I would just start a topic ...
Are there different "ELM 327"s for different vehicle manufacturers?
I am most interested in a Bluetooth unit that I can use with my phone, or with an adaptor on my laptop, etc., but can I purchase somethign like this >>> eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices <<< & utilize it not only on my 'Carlo, but my Pop's Buick Century? My Mom's Eclipse? Friend's BMW?
Old Mar 4, 2012 | 11:19 AM
i'm pretty interested in this too. But as far as i know its like an OBDII scanner, should work in any car with an OBDII port. What app were you gonna get for you phone? I had a topic for car apps somewhere, thats probably the one you posted in
Old Mar 4, 2012 | 11:21 AM
xxtheshockerxx's Avatar
RED DEVIL
that is the bluetooth obdII I have. it will work on anything with that port. I use Torque also.
Old Mar 4, 2012 | 11:37 AM
and you didn't chime in, in the smart phone apps topic How is it, what all will it display on your car, tell us
Old Mar 4, 2012 | 12:08 PM
RED DEVIL
I use it mostly for clearing codes, trans temp, intake temp, coolant temp, volts, and 0-60 . There is a huge list of things it will monitor probably over 100. some can be a little tricky to get working but once you get it working it always works really good. I had trouble with the trans temp for awhile.
Old Mar 4, 2012 | 12:18 PM
RED DEVIL
here is the display i use the most
Old Mar 4, 2012 | 12:51 PM
Like i said in the other topic, i think i'll get it in the near future. I'm interested in my coolant temps, see if i have a busted thermostat or not. Have you tried the HP/Torque features? and thanks for postin zach
Old Mar 4, 2012 | 01:01 PM
RED DEVIL
i cant get the HP function to work right. last i tried i was getting 125 hp i see they did at WHP as a function in the last update. I might have to try to get it working right next time i have it out
Old Mar 4, 2012 | 01:50 PM
125hp? geez you lost alot of power
Old Mar 4, 2012 | 03:03 PM
Rellsun's Avatar
to do the hp/torque you have to put your car manually into 2nd or 3rd (I forget which one) so the car doesn't shift. maybe that's your problem?
