Need answers about rims/STOCK CHANGE TO AFTERMARKET
Hey guys so there is some rims I'm looking at that are on sale my ? is what is the stock specs of the stock rims for a 2005 Monte Carlo SS supercharged rims and are these specs ok for the car? I will list the specs below. I need new tires so tires ar enot a problem just need to know if there is any differance from stock that would make these rims not right. I searched 2005 monte carlo ss/sc on tirerack.com n found them
OFFSET 4OMM
BACKSPACING 6.10"
BOLT PATTERN 5-115
OFFSET 4OMM
BACKSPACING 6.10"
BOLT PATTERN 5-115
Other set of rims i want specs are
Offset 42 MM
Backspacing 5.94"
bolt pattern 5-115
which sounds better due to offset and backspacing if either plz help asap lol this is going to be my birthdya present to myslef
Offset 42 MM
Backspacing 5.94"
bolt pattern 5-115
You should post this in the rims/tires section it might get a little more attention.
As far as the TPMS, you don't absolutely need it, you may get a code without them, i didn't tho
You don't need tire pressure monitors because 2005 monte's don't use tire pressure sensors they use wheel speed to monitor tire pressure..
