6th Gen ('00-'05): My Up and Coming Mods.
Once I get the money for them, which for the glasspacks shouldn't be long. I'm also probably going to get a u-bend delete, and also a res delete if I think it's not loud enough :P.
KYB - KYB GR2/Excel G Struts # --- Father paid for strut replacement instead and i ended up with gabriels.
MagnaFlow 99306HM - MagnaFlow Heavy Metal Catalytic Converters - Overview - SummitRacing.com
or
SLP Performance 30073C - SLP Performance High-Flow Catalytic Converters - Overview - SummitRacing.com
Summit Racing® Glasspack Mufflers - SummitRacing.com
or
sounds like a great start
there is also a company that is now sponsoring us here on mcf called cold air inductions maybe check into them as well...
https://montecarloforum.com/forum/ve...uctions-34945/
^^link for cold air inductions^^
i would for sure do the "U" bend delete! good luck with modding your monte, keep us updated with pics etc as you get the mods completed
i was think the same thing,
i agree then you eliminate stock doubble wall restriction and u bend at the same time
Amazon.com: Lawson Industries 77922 INSYNERATOR Bullit High Performance Muffler: Automotive
And
I'll try
But that's a good idea, I didn't know the ZZP Downpipe had a highflow cat on it. Thanks I'll probably go that direction for the cat
Dunno what the double wall restriction is :O
No, you can't just bump threads, we can consider that post-whoring and it is against our rules, if you want to keep trying though, go for it
Double-walled is a term for how our downpipes are.
If you look at the pipe, it is really a pipe, INSIDE of a pipe. So it has 2 pipe walls, which means the outer-diameter is really smaller and inside of a pipe.
Does that make sense? haha, basically you just need to know it is a major restriction.
