My relay on my hid kit is buzzing?
Old Apr 19, 2009 | 02:21 PM
SolowSS's Avatar
Just call me Dubs
Default My relay on my hid kit is buzzing?
I was flipping though the owner manual on my new car and thought to myself it would be straight if my new car used the same buld (9006) as my Monte Carlo did and just my luck it did so ofcourse as soon as I get home this morning I starting installing it in the new car.I get everything all done and test it and everything works fine so I started the and after I started the car I saw the beams jumping and the lights flickering and then I heard the relay start buzzing so I turned the lights off and it went away.I've tried everything even just the plug and play without the relay and that only worked for so long I had the same problem with my Monte Carlo but the relay never buzzed and made the lights licker and jump what could be the problem.
Old Apr 19, 2009 | 07:57 PM
inssanity21's Avatar
i have never heard of that problem. mayby not enough electricity?????? but what car did you get?
Old Apr 19, 2009 | 09:03 PM
nemesis's Avatar
2009 Monte Of The Year
did you install a separate wire harness
Old Apr 19, 2009 | 09:45 PM
SolowSS's Avatar
Just call me Dubs
I don't know maybe it works fine when the car is off so why wouldn't it work properly with the car on. I got a 300
Old Apr 19, 2009 | 09:46 PM
SolowSS's Avatar
Just call me Dubs
when I first bought the kit it didn't come with a relay harness I bought it seperate.
Old Apr 21, 2009 | 11:46 PM
nemesis's Avatar
is the buzzing come on when you turn the hid on without starting the car? if that's the case that's normal. all it is the ballast warming up. mine does that too. been 2 years now since i have my ebay hid. you should get a separate harness for that tho cause it will make the hid brighter. the hid get it's juice straight from the battery not sharing the power from dash lights and other accessories. the harness also will help eliminate problem like static on the radio or perhaps maybe a different kind of buzzing sound other than the one i explain. btw what year is the chryslar 300 you bought? so you not going to get another monte?
MJClemm
Dec 12, 2012 02:21 AM
sotmelo
Dec 19, 2009 05:07 PM
Berg01SS
Jul 21, 2009 08:59 PM
MBZZR
Jul 3, 2009 03:25 PM
ricrush
Sep 6, 2007 11:18 AM
