low wiendshield wiper fluid
Old Jan 26, 2010 | 10:13 PM
silver1's Avatar
Default low wiendshield wiper fluid
i filled it up but the light stays on. anyone have this problem? i have an 03 monte ss. also, what gen does that make mine>
Old Jan 26, 2010 | 10:17 PM
have you ran it through and shot it?
Old Jan 26, 2010 | 10:28 PM
gen 6 for you and that light should go out soon, I hope, mine did!!
Old Jan 26, 2010 | 11:03 PM
silver1's Avatar
ya i ran it through a little. not much though. i probably ran it 3 times at the most for like 5-10 seconds each time. maybe run it some more?
Old Jan 27, 2010 | 07:46 AM
Cowboy6622's Avatar
The computer has an order of sensors that it goes through, I suppose window washer fluid could be one of them. I know on my car if you leave the fuel cap off and the computer detects it, even if you put it back on, the light won't go back off. You'll have to drive a couple of hundred miles sometimes before the computer sends a signal nad realizes it has a fuel cap again and shuts hte light off. Just give it time!
Old Jan 27, 2010 | 07:59 AM
You can d/c your battery for a few minutes and reset the PCM and the light should go out. If the light doesn't go out, you could have a sensor that has gone bad
Old Jan 27, 2010 | 08:40 AM
MAMONTE's Avatar
Its should go out instantly when you fill it with fluid. Both the light in my Monte, and the Bonneville go out as soon as you fill it with fluid, just like the gas light goes out as soon as you put gas in the car.
So I would lean towards you having a bad sensor.
Old Jan 27, 2010 | 10:15 AM
kweef's Avatar
I agree. With Duane's gas cap being off the computer recognizes it as an evap leak. Due to obd II standards, the light will not go off until the car has been taken thru 2 complete drive cycles and the leak has not been detected. Only then will it shut the light off
Old Jan 27, 2010 | 08:33 PM
Cowboy6622's Avatar
I think it's a ridiculous waste of weight in the car anyway!! If you hit the button and the windshield fluid doesn't squirt out, then there must not be any! Not hard to figure out.
A bad sensor makes sense though.
Old Jan 28, 2010 | 12:49 AM
silver1's Avatar
lol i agree!
so it is still on, i used it alot for no reason today in traffic. people looking at me funny but it's ok. what is "two drive cycles?"
