Lot's of water.
Old Jun 7, 2010 | 12:45 PM
Sir Monte's Avatar
Default Lot's of water.
Well today started good till me and the better half were going to go to the store. She opened the door and stepped in a LAKE on the passenger side. I said holy s%$#, about 3 inches of water on the floor. After looking at this for a while I found out that the headliner was wet and figured that the Moonroof has a leak. My question is how do you fix this leak, better yet where are the drains for the moonroof? Thanks in advance.
Old Jun 7, 2010 | 01:18 PM
Sir Monte,
Sorry to read about your flood
Check out a prior thread on this topic...
Hope it gives your some idea's on what to check `out.
Also, use our MCF Search Engine for more infor/posts
on the subject.
Hope the below gives you a start.
Wish you Good Luck & a fast resolve to your `prob.
https://montecarloforum.com/forum/sh...ht=water+leaks
Click above link to explore thread & several links on the subject.
Also, check back on your thread to see what other
member's have done to repair this problem...
Peace/Happy/Out
Old Jun 8, 2010 | 03:08 PM
Sir Monte's Avatar
Well, I found the problem. the drains for the Moonroof were plugged with dirt and leaves. The drains follow the front door pillars and you can get at them by removing the kick panels and pull back the carpet. You will see a rubber hose about the size of your pinky finger (3/8) diameter. Check to see if the are clean. I took compressed air and blew them out. I opened the moonroof and poured water in the front edge of the moonroof and watched drain to the ground via the cleaned out drains.
81Monte350Power
Jan 20, 2008 10:51 PM
81Monte350Power
Jan 5, 2008 10:00 PM
Brooke
Oct 17, 2007 04:35 PM
ronchable2
Aug 29, 2007 02:51 PM
BeachBumMike
Jul 12, 2007 05:58 AM
