List of issues on my Salvaged '02
Alright, so my '02 Monte Carlo SS/HS still has some issues and I just want to get them all out in discussion so I could get some answers. I apologize ahead of time if this post is under the wrong thread. Alright, so here we go...
Sunroof barely moves before coming to a stop. Makes a grinding type of noise but after further investigation, I noticed what I believe is the motor tends to turn slightly. Could it be just a loose bolt? Or motor? Stalls frequently. When driving in town at low speed/rpm, the car will just shut down. I loose power, power steering, and the battery warning comes up on the Message Center (which I assume is normal, since I got my battery new for Christmas). Then I have to come to a stop, put it in Park, and fire it back up (Seems to always fire right back up). Also, when it's warmed up and the temp. gauge is at the halfway mark and I turn the car off and restart it, it either won't start or if it does, quickly shuts back down. Seems to always be the third try for it to start back up. I'm not sure if my transmission is the cause of any of this because I do know its time is about up. Today, I was driving down the road with my Cruise Control set on 57 mph like usual, then I heard a really quiet snap. I pulled over in town and replaced the fuse. Then as I was on my way back home, I set it and it worked. Then about 5 miles later, it went out again. The green light stays on on the steering wheel, but can't set cruise control back on. Some other minor issue are: -Fans turning on/off at low temps. -Broken plate on rear windshield for Rear Defrost, best way to fix? -How do you get rid of trunk rattle from subs without loosing sound? -Steering wheel slightly shaking while driving. That's all I can think of at the moment. Any help towards finding solutions, I'd appreciate it greatly. Thanks! |
My sunroof would stop halfway because it was all gummed up with old grease. I cleaned it all up and re greased it with some white lithium grease and it works fine now.
(Post 530610)
I would definitely check the motor and the slides to make sure everything isn't blocked.
The car shutting off. Check and clean that MAF sensor, when hot starts fail I usually look to the MAF first. IAC is also a culprit (as well as the ICM) Fans kicking on for no reason? Does the fan stay on after you shut the car off sometimes? That could be indicative that the sensor that tells the temp could be going bad and the fans go into a fail safe mode where they just stay on because they don't know the actual temp of the car. Rear defrost, get a kit from an auto parts store. You can dynomat the car to help with rattle, or just turn down the bass. Steering wheel shouldn't shake, could be a wheel hub starting to go, could be a loose lug, could be the rotors, a suspension piece, etc. You are going to have to jack the car up and start moving everything. |
One more thing. Just noticed the hud that shows gas mileage, temp., direction, etc. no longer turns on. Could that somehow be related to Cruise Control since they both went out at roughly the same time?
(Post 530686)
I kept my system stock, I care more about my engine than the sound from the radio ;)
The most I've done was replace a burnt out front left speaker. |
Originally Posted by ..Scar'lette..
(Post 530707)
I'll check it all out. But dont dynomats work a little too well? Dont they really drain the sound? And turn the bass down? C'mon, be real ;) hah jk
(Post 530603)
(( EDIT: If you live in a very cold climate, you may have trouble starting your MC when she's dead cold. In that case, plug the MAF in, start 'er up, then unplug her again. Even while the engine's running. Again, I stress you WONT hurt your engine any by running without your MAF plugged in. The ECU will rely more heavily upon MAP sensor readings and Factory (assumed) parameters and maps. )) The fuse being blown repeatedly sounds like a short, honestly. Meaning I'd be curious what they (previous owners) were doin' tinkering behind the console. Only time I ever crawled up there was to install my Remote start. I'd start looking for any Shorts, most likely somethings simply grounding out against the frame somewhere. I'd start under your dash, drivers side. o7 |
When my car did the whole stalling thing it was all from my CAT being bad. If what the others said doesnt work check that out.
| All times are GMT -5. The time now is 01:07 AM. |
