lg4 motor making ticking noise by intake need help asap
Old Jan 20, 2007 | 02:43 PM
87monte's Avatar
Default lg4 motor making ticking noise by intake need help asap
loud ticking from idle to full wot...wondering wat is it?im thinking a lifter ?what should i do?
Old Jan 20, 2007 | 03:41 PM
DESS03's Avatar
Default RE: lg4 motor making ticking noise by intake need help asap
ticking by intake sounds like lifters
Old Jan 20, 2007 | 03:45 PM
mickey's Avatar
as far as what can you do?
replace the lifters. with new ones. also if you do it i would check in to a larger set of lifters and a better cam. this will allow it to breath even better then it dose now.
Old Jan 20, 2007 | 03:56 PM
88ss408's Avatar
are you sure its not just a rocker ?
Old Jan 20, 2007 | 07:27 PM
87monte's Avatar
not sure what it is it jsut started after my first oil change on the rebuild.and i put synthetic in it instead of the regular kind..now i have to take it back to the shop to fix this..well how could of this happen..i should just up grade since it will be open
Old Jan 21, 2007 | 07:48 AM
mickey's Avatar
if you have it open anyway i would upgrade.
if they just rebuilt it it could be a liffter didnt pump up right also.
Old Jan 21, 2007 | 10:05 AM
88ss408's Avatar
yeah its probley a lifter that did not pump up
Old Jan 22, 2007 | 12:37 AM
87monte's Avatar
how this happen
Old Jan 22, 2007 | 05:09 AM
mickey's Avatar
most of the time this happens is they were supposed to be soaked a certain amount of time in Oil and they didn't get enough time
OR
some are just bad from the factory. nothing you Can do about them
OR \
something plugged the holes in them and it is causing it to not get enough oil
there are a lot of reasons but for the most part those are the ones i have seen the most.
Old Jan 22, 2007 | 07:06 AM
87monte's Avatar
thanks!im worrried thinking i did something wrong
