Just Ordered HP Tuners VCM edit for my 07 SS
Old May 15, 2007 | 09:33 AM
AFAN4_29's Avatar
Default Just Ordered HP Tuners VCM edit for my 07 SS
I just ordered it online Monday, hopefully it will be here by the end of the week. Looks like you can change alot of settings with it. Does anyone have one of these? It comes with 8 credits, so you have the posibility to program4 vehicles (most vehicles take 2 credits). Cost $509 with shipping.
Old May 15, 2007 | 03:07 PM
rj's Avatar
rj
Default RE: Just Ordered HP Tuners VCM edit for my 07 SS
Not to sound stupid...... but what is one of these?
I assume it's some type of stereo equipment?
Old May 15, 2007 | 03:23 PM
wiz kidd's Avatar
it will be some sort of programmer that your plug into your computer under the dash, and you can program all sorts of stuff...
they usually have a few different settings on them that work fairly well...
i haven't tried it on the monte but i did use one on my truck and it worked really well
Old May 15, 2007 | 03:34 PM
rj's Avatar
rj
That makes better sense. Thanks.
Old May 15, 2007 | 10:34 PM
AFAN4_29's Avatar
Sorry about that....I guess I should of gave more info. Yes it is a editor for your vcm/pcm in a gm vehicle and virtual dash. It comes with the software to install on a laptop or desktop and the vehicle interface to connect it to your obd ii port. It suports alot of GM vehicles. It lets you edit over 300 items. Here is there website: www.hptuners.com There is also screen shots of the program on their site.
Old May 15, 2007 | 11:46 PM
cain45's Avatar
why would you want to "edit" something on your car?
Old May 16, 2007 | 09:10 AM
wiz kidd's Avatar
for horsepower...its not really editing...the programmer has set programs for each engine that it puts in...
usually 3 different levels
basic which is just a little step up that lets you use regular gas still
better which you have to use 91 gas and its a better performance gain that basic
then theirs the best one which you have to use like 94 octane gas but its a huge jump in the hp...i think it changes stuff like shift points and different ratio's and stuff...
not 100% sure..all i know is it worked really well hp wise on my truck
Old May 16, 2007 | 10:43 PM
FlynhghR's Avatar
How long does it take to do a run through the settings? Like if you wanted to put in high octane to race on the weekend then go back to pump gas for the week?
Old May 17, 2007 | 07:11 AM
wiz kidd's Avatar
on my truck it was just like a 3-5 min job...very quick...maybe even less than that...
it was a superchips programmer
i would imagine the ones for our monte's do the same thing
Old May 17, 2007 | 05:30 PM
04 Intimidator's Avatar
The HP Tuners programmer is a little bit more complicated than that. As you can see below it is a decent list, but its not all Yes/No questions. It allows you to make changes to fuel maps and various other functions as well.
Engine
[ul][*]EGR, Air Pump, COT Enable/Disable and controls[*]Rev Limiters, Idle Speed and characteristics[*]Throttle Follower and Cracker[*]MAF Tables, Main VE and Cranking VE[*]Power Enrich fuel controls[*]Closed Loop/Open Loop characteristics[*]Injectors[*]Spark Advance and Retard[/ul]
Engine Diagnostics
[ul][*]MAP Error Values[*]MAF Error Values[*]Misfire Values[*]DTC's[/ul]
Transmission
[ul][*]Shift Speeds[*]Shift Firmness and Time[*]TCC Parameters and Tables[*]C.A.G.S.[/ul]
Transmission Diagnostics
[ul][*]Trans Slip Test Conditions[/ul]
System
[ul][*]PRNDL Flag[*]Fan Type Select[*]VATS[*]Fan On/Off Temps[*]A/C Parameters[/ul]
Speedometer
[ul][*]Speedometer[*]Speed Limiter[/ul]
