interior painted
Old 06-08-2010, 09:15 PM
jarheadbobandmax's Avatar
Photobucket
painting the interior vinyl & plastic peices can be done with crylon fusion which is a excellent paint..I've found it flows out and settles great....I've been working with my interior the past couple weeks taking it just the opposite direction playing off my new tan leather interior I'm taking the headliner to a desert tan, the lower dash, doors and side panels are almond with kahki inlays. the instrement panel and all black is now fusion hammered metalic black...I've found on plastic and vinyl if you use fusion as a base you can follow with a regular secound and third coat of any shade crylon and clear,,fusion will bond to the surface and then pull in and hold the top coat. I'll post pic's as soon as I put it all back in
Old 06-09-2010, 01:28 AM
JAlva's Avatar
Originally Posted by jarheadbobandmax
painting the interior vinyl & plastic peices can be done with crylon fusion which is a excellent paint..I've found it flows out and settles great....I've been working with my interior the past couple weeks taking it just the opposite direction playing off my new tan leather interior I'm taking the headliner to a desert tan, the lower dash, doors and side panels are almond with kahki inlays. the instrement panel and all black is now fusion hammered metalic black...I've found on plastic and vinyl if you use fusion as a base you can follow with a regular secound and third coat of and shade crylon and clear,,fusion will bond to the surface and then pull in and hold the top coat. I'll post pic's as soon as I put it all back in
nice i look forward to seeing yours. i played it safe with using vinyl paint because the fusion paint felt a little thick i wasnt sure how it would go on the vinyl. i put like 4 coats of paint total since i had extra paint plus the 3 of clear coat. overall like i said i was happy with it maybe little things i would of done differently. but your color scheme sounds pretty nice i look forward to seeing that. as for your headliner are you wrapping that or dying it?
Old 06-09-2010, 02:24 AM
HONESTLY i lookz gr8 man i like the way it came out i hope u put bulldog on it so it wont peel or flake up awesome job now all u need is some black leather seatz LoL!
Old 06-09-2010, 05:50 AM
Photobucket
as for your headliner are you wrapping that or dying it?[/quote]I'm wrapping it , the reason for the entire interior re-do is that the car fell victim to one a flood and second the previuos owner was a heavy and carless smoker of many things. burn and nico stains all over the headliner
Old 06-20-2010, 10:18 PM
JAlva's Avatar
[/quote] I'm wrapping it , the reason for the entire interior re-do is that the car fell victim to one a flood and second the previuos owner was a heavy and carless smoker of many things. burn and nico stains all over the headliner [/quote]
hey Tim, hows the interior coming along have you finished it? if so post some pictures i want to see how it turned out.
Old 06-21-2010, 05:17 PM
This question comes up all the time. There is more than 1 way to do it. So I wrote down how I do it. It seems to work out perfectly.
Works equally well with automotive paints and spray can paints.
If you have something you can add to it, feel free to post it here and let me know.
To make sure your panels are oil free, like from Armour All and pooo, wipe them down several times with a wax and grease remover. If they are really Armour All'ed down, use a brake cleaner.
Get a bucket of soapy water to wetsand with.
Sand the grain out of them with a 80 grit wetsand. Get at least 75% of the grain out. Then wetsand with a 150 - 180 grit. Then move to a wetsand with 220 grit. If for some reason you are odd and like the grain look, skip that part.
Clean the panel again with wax and grease remover and also a tack cloth. I suggest wearing latex gloves to keep oils from your hands transfereing to the panels.
Spary the panel with an Adheisive Promoter. Follow directions on can.
Spray with FILLER primer. As many coats as are needed to fill in all the grain. For small items such as trim panels, kick panels and pillars, SEM makes a filler Primer that is awsome or you can use Duplicolor Grey Filler Primer. They also have a red rust colored filler primer. Avoid it. For some reason it sand horrible.
Wetsand that with 220. If you see your self going to deep into the plastic before you are happy with the finish, dry and clean the panel off with wax and grease remover and spray more primer on it. Keep this process till happy. Final wetsand with 400 grit.
Clean the panel with wax and grease remover and a tack cloth and then paint.
Spray as many coats as you like, 3 is usually plenty, and do it in light coats as heavy will clog and run and then you have more sanding to do.. Let it dry in the sun if possible as long as you can. Overnight is prefered. If you feel there are some imperfections, wet sand with 600 or more till you are happy. Clean it real good and then spray a clear coat over it. Again in light coats.
I try to let the clear coat dry for a couple days for best results.
__________________
If doing a dash
If you want it just painted, follow the steps above to clean and prep it and then paint it.
If you want it smooth for a glass like finish, clean and prep it as above and then lay several layers of filler primer over it. Do that in 3 steps or so till all the grain is out. Sand it smooth using the wet sand method and 220 grit. The lay some paint on it.
Now understand this..... if you push really hard on top of the dash, you can crack it. Although in all my years I have yet to see someone lay on top of their dash, or kneel on it. I suspect your dash will last for plenty of show seasons. I know people who have done this plenty and the dash looks awsome still.
__________________
remember Armour All is the Devil.
Unless of course you have a stock interior, then it works good.
For painted peices, I use ZAINO S or Meguiars Quik Wax after the paint is cured once a month and Quick Detailer when you want to clean it. Spray on, wipe off, flip cloth and wipe again
One other thought,whenever possible use a gloss paint and skip the clear. The fewer number of products the smaller the chance for a reaction between them. For cars that are not strictly show cars i would never use anything more than satin finish on top of the dash. We've had to dull the dashes in new cars for customers that couldn't stand the glare. Interior paint is typically 12 degree gloss i think. That's about as much as you want to have. in your line of sight
Franks 03SS
09-11-2011 07:52 PM
Nuffy
08-29-2011 07:41 PM
zzapultimate
15
07-24-2011 06:32 PM
1BADSS
11-04-2009 09:19 AM
Patrick
05-30-2005 02:28 PM
Quick Reply: interior painted
