Opinion Needed: Ignition Cylinder Lock Locked In Off Position 02 MCSS
Old Oct 18, 2020 | 10:34 AM
Max_Lenn's Avatar
Default Ignition Cylinder Lock Locked In Off Position 02 MCSS
Hi everyone,
My 02 SS ignition cylinder is currently locked in the off position. I tried moving the key down a bit as shown in a YouTube video but didn’t work. I need some ideas on how to get my car started.
Thanks
Old Oct 18, 2020 | 12:41 PM
Jeffs02rwdSS's Avatar
It happened to my car also , the one way I solved the issue was with a new key tumbler. Which btw is a pain because you must drill out the old lock and then relearn the key switch. You will have to search to find the procedure but it's about the only way to remove the switch because the switch must rotate to remove it from the harness. Good luck
Old Oct 20, 2020 | 10:40 AM
I had that procedure completed at the local shop (not a GM dealer) that does all my work.
The new cylinder on a 2006 Pontiac Torrent was $185.00 installed. This worked perfect after that.
The_Maniac
FWD Tech Guides '95-'07
Mar 20, 2021 08:41 PM
kody02ss
Dec 12, 2011 12:09 AM
Holly19
Nov 18, 2011 06:14 PM
jeremyjlewis02
Oct 24, 2011 01:28 AM
big green dog
Jan 7, 2010 11:18 PM
