How to Change front brake pads???
Old Feb 20, 2010 | 11:55 AM
01_Monte_SS's Avatar
Default How to Change front brake pads???
I know its pretty simple but, am planning on replacing them on my own and want to change them properly...
Old Feb 20, 2010 | 08:27 PM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
remove the two bolts from the caliper, remove the pads. You will more than likely have to push the piston back on the caliper. I usally take a block of wood and a c-clamp to puch it back. take the lid off of the brake fluid resevoir so the fluid can puch back. Put the pads back on and bolt the caliper back in place.
Old Feb 20, 2010 | 09:08 PM
I just leave the old inner pad in there and use that.
One note for the 5th gen guys with rear disks- the rear calipers can't be compressed by this method, they must be screwed back in- they sell a little cube with little tongs for the job or you can improvise.
Old Jun 8, 2010 | 06:13 AM
sjplaya33's Avatar
thanks really needed this info havent changed the breaks since nov of 06
Old Jun 8, 2010 | 06:49 AM
How to Change The Brake Pads in Your Car - wikiHow
Feb 25, 2010 ... wikiHow article about How to Change The Brake Pads in Your Car. ... ONLY as a very general guide on how to change your brake pads. ...
www.wikihow.com/Change-The-Brake-Pads-in-Your-Car - Cached -
Similar
Easy, Illustrated Instructions on How to Change Brake Pads
Each wheel of a car has two brake pads set up to give it a squeeze when you ... When I changed Stacy's brake pads last summer, I took a bunch of photos to ...
www.cockeyed.com/lessons/brakeshoes/brakeshoes01.shtml -
Plus Vid's Hope it helps..Good Luck
How to Replace Front Brake Pads : Compressing ...
3 min 55 sec - Mar 11, 2008
www.youtube.com
Maintenance and How-to: Changing Break Pads
3 min 9 sec - Aug 26, 2008
www.youtube.com
Old Jun 8, 2010 | 07:44 AM
MAMONTE's Avatar
I always change my own brakes! I think brake jobs are ONE of the largest money makers for some of these shops. Most brake jobs can be done by the pro's in an hour or less (per axle) and they charge crazy amounts for the work. Tire shops love to hit people up for new brakes, and take you to the cleaners while doing it. Disc brakes especially are a rip off to have done..
You can buy OEM equals at autozone (new pads, and new rotors) for the front for right around $100. So for $100 you could have new rotors and pads...try going to a shop, you could be out the door as much as $500-600 for just the fronts. All 4 wheels, $800+ at the shops. Do it yourself, less than $200.
Its really an easy thing to do yourself too.
Old Jun 8, 2010 | 10:12 AM
Dyonysis's Avatar
I agree with MAMONTE. Shops always rip you off on disc brakes. The first time I did my wife's Sante Fe (disc brakes, but unknown setup) I was proud to do the front end in 15 minutes (from wheels up to back on the ground). Were I a shop, that would be one hour shop time (@ $100+).
Old Apr 14, 2011 | 01:58 AM
archebald23's Avatar
This is a good resource in reading up and having a good idea on how to replace brake pads, specifically the front brake pads of your vehicle. This would help us on how to really have things work out on your vehicle when applicable. Hope that all is well with you guys!
Old Apr 14, 2011 | 07:25 AM
EarnhardtZ71's Avatar
I just replaced the pads on all 4 corners of my car. I bought the OEM ceramic pads from the Chevy dealership. They were $60/set so it was only $120. I use OEM stuff as much as possible.
I swapped all pads and replaced both rear rotors in about an hour and a half, using the same method as donutboy.
Old Apr 14, 2011 | 10:13 AM
JaxJim's Avatar
Look on youtube for some videos. I've found that to be a great place to actually see what needs to be done.
