5th Gen ('95-'99): hit a deer
Old Nov 5, 2015 | 05:55 PM
muleys99's Avatar
Default hit a deer
So,coming home from work Monday about 6pm I hit a deer in my Monte.Well, the damage is unknown other than a caved in hood and busted headlites as I havent gotten the hood up yet.Any ideas how to get it open? Big channellocks and peel it back? Its dark when I get home now and kinda rainy but gotta fix it as its my only ride right now.
Guess I was kinda lucky as no coolant loss but the fans may not be working.
Any ideas are greatly appreciated. Muley
Old Nov 5, 2015 | 06:41 PM
Question
Not sure what it looks like? So this is only a guess. If you get the traditional pop on the release but it still doesn't move. I would use a pry bar to try an open the thing up. If you break something you can usually rope it back down. Also if you can crawl under the front end and see what you can spot with a flash light that may give you a better clue on the damage. You might need to put a wheel up on the curb to get under it and do this too. Don't use any wood under it to make a ramp as it may not be safe.
Old Nov 6, 2015 | 08:37 AM
muleys99's Avatar
Hello,Driver#3 Tthe damage is centered between the headlites.Mashed the hood,broken lites, no damage or little damage to the bumper cover. My main concern is if the fans are messed up or not running.Drove it home prolly 5 miles no coolant leaks but the outside temp was pretty chilly. This is 2nd time Ive hit a deer with this car, didnt get it fixed right then,now this. I like this Monte even with 200k miles.I really dont want to put a lot of money in body work just need to drive it for a while longer,maybe thru winter. This has been a great car,and Ive never been deer hunting in my life,I swear. Ill get under it later, raining now.As before,thanks for your reply. Muley
Old Nov 6, 2015 | 10:31 PM
Smile
Maybe there is a salvage yard close you can get a hood for it. Some Stated if you hit an animal they let you harvest the meat? Now is the time the Deer are out there so be careful for sure.
Old Nov 7, 2015 | 11:10 PM
nitehawkjcb's Avatar
Be prepared to replace your hood latch too, unless you can un-mangle it.
