High Miles Club
Great Thread `Jon, thanks member's for your posts 4-Sure.----------------------------------------------------------------------
The Top 10 Rules of High-Mileage Car Maintenance
(ARA) - Americans are keeping their vehicles longer and driving farther than ever before. Today, the average age of vehicles on the road is greater than nine years and more than 68 percent of vehicles have more than 75,000 miles.
As a vehicle's engine ages, its performance decreases and oil starts to break down at a faster rate. Over time, seals begin to deteriorate, gaskets become brittle and oil consumption increases -- all leading to a reduction in engine performance.
Treating your high-mileage vehicle with a little TLC and consistently following the 10 rules for high-mileage vehicle maintenance will help ensure it will go the distance. Using premium motor oil specially formulated for higher-mileage cars -- such as Castrol GTX High Mileage Formulation --will also help a higher-mileage car feel young again.
Rule #1 -- Make sure you change your oil every three months or 3,000 miles -- whichever comes first. No exceptions. Think of your engine as the heart of your car and motor oil as the lifeblood of the engine. One can't function without the other, so stay on top of your oil-change schedule.
Rule #2 -- Find a good mechanic. If you don't do your own maintenance, find a shop staffed by ASE-certified mechanics (that's the American Society of Engineers). A good mechanic will listen to your questions and explain procedures clearly.
Rule #3 -- Have your tire pressure checked at least once a month. It's the best way to prevent unexpected flats. A service station attendant can quickly and easily perform the check. Also make sure to rotate your tires and check their alignment as part of a regular tune-up (or with every other oil change).
Rule #4 -- Pay attention to warning signs. Of course, not every little thump or ping you hear spells disaster. Cars, like people, have their peculiarities, and you are sure to quickly learn what is normal for yours. With a high-mileage vehicle, however, it's best to check out any symptom --- be it a sound, smell or feeling -- that seems the slightest bit abnormal. Remember: an ounce of prevention is worth a pound of cure.
Rule #5 -- Pay attention to outward signs. If your car is leaking fluids, it can mean serious trouble. Keep an eye on the conditions of your driveway or regular parking space for stains or spots that can warn you of possible leaks. Castrol's GTX High Mileage Formulation motor oil contains special conditioners that help protect and maintain seals, thereby helping to reduce leakage -- a common problem in older, higher-mileage engines.
Rule #6 -- Schedule regular tune-ups. Even if your high-mileage car seems fine, that's no guarantee it is. Use tune-ups to ensure your car's major components are running smoothly and that they stay that way. Your oil should be changed, tires checked and rotated if necessary, belts checked and replaced, brake lines inspected, spark plugs and air filter checked and replaced, and fuel injector checked. A good way to top off a tune-up is an overall analysis of your car's engine, and undercar, safety and computer systems.
Rule #7 -- Prepare your car for the seasons. If you live in a sunny climate all year round, you can skip this step. For the rest of us, visit the "Ask the Expert" feature at www.castrolusa.com for a checklist of seasonal maintenance practices for your high-mileage vehicle. Preparing your high-mileage car to defend against the elements will lessen its chances of needing repairs and save you money in the long run.
Rule #8 -- Check your fluids regularly. It's dangerous for your high-mileage car to get dehydrated, so be sure to keep an eye on its vital fluids. Simply lift the hood and perform a quick visual check. Use the dipstick to check the oil level; a quick glance at the coolant reservoir will let you know if you need more cooling fluid.
Rule #9 -- Store it properly. Storing your vehicle in a dry, temperate location when it is not in use will prevent disastrous wear and tear on both its interior and exterior. Garage your car whenever possible to protect its looks.
Rule #10 -- Stay on top of safety features. Nothing is more important than your car's ability to protect both you and your passengers. Air bags, antilock breaks and any other additional safety features that you may have added to your car should be carefully checked on a regular basis (when your car has a tune-up) to ensure that in the event of an accident, they will perform their vital, lifesaving functions
holy chit man, that's alot of miles.....
142K in our '02 Monte. Have always used fully synthetic oil (currently using Castrol). Hardly ever a day of trouble from it, so I'm assuming 200K shouldn't be a problem. I'm hoping for 300K.
About 185K on my old car ('90 Jag XJS). Still going strong as well. Dino oil in that one: 20W50 in summer, 10W40 in winter.
My 01' Monte SS has roughly 117,000 and runs like a top and is in great condition. I switched over to Castro full synthetic oil at 115,000 and noticed a definite difference immediately. I just did the Tranny fluid/filter with Castrol synthetic blend fluid and seems to shift a little smoother. Then I flushed the radiator and I am running Firestone Firehawk Gt (pursuit) tires, had brakes done, alignment. All is good however, the issue is there is a small leak coming from somewhere underneath right now, I am blaming the power steering ( replaced in may 2011) and i did notice the valve cover has a slight sign of seepage.
So, I guess my question is what are the typical causes of a miscellaneous fluid leak. fluid color is reddish.
I remember one time I was on a flight coming back to Seattle and there was this knockout redhead stewardess I couldn't take my eyes off. After we took off and everyone was settled she walked past my seat and brushed her leg against my arm as she passed by. I followed her with my eyes as she walked to the rear of the plane. Then she looked at me, smiled, winked, then motioned with her finger for me to follow her as she stepped into the bathroom. I got up, walked to the rear of the plane and...wait a minute...the title said high mile...not mile high...nevermind...
HA HA NICE!
Monte still at 195k lol working it's way back to zeroK
Saturn 225k
Intrigue 177k
