6th Gen ('00-'05): high idle speed
Old Oct 20, 2017 | 11:22 PM
claydoh's Avatar
Default high idle speed
ive seen a couple post on this but not the same as mine, my 03 ss will go into high idle around 1500 on tach ,then next time I crank it drive normal ! I have no check engine light to check codes. I have seen to check or replace the IAC and the TPS but I don't want to just "throw" money at it til I find the problem. seems strange it does it on way to work then not on way home etc. ?? any ideas?? thanks ! Claydoh
Old Oct 21, 2017 | 07:31 AM
user 35764368's Avatar
You can try cleaning the IAC ,, very easy....it gets pretty carboned up in there... over time.
Old Oct 21, 2017 | 07:33 AM
claydoh's Avatar
just remove and use mass air flow cleaner ? what about the TPS?? thanks
Old Oct 21, 2017 | 07:42 AM
yes take it off and clean the end if it only...the pintle its called I believe. I used carb cleaner. take a paper towel and soak it good with the cleaner and use yer finger to poke it in to the throttle body hole and clean where the pintle comes in contact with it... yull know when its clean enuff cuz yu will see a shiny round ring.
Old Oct 21, 2017 | 07:43 AM
the TPS can be tested with an ohm meter. the procedure is on yutube somewhere.
Old Oct 25, 2017 | 12:50 AM
claydoh's Avatar
thanks for replies, I cleaned the idle control valve, it was very black and it seems to have fixed the problem! thank you sooo much!!!
Old Oct 25, 2017 | 05:50 AM
