HID conversion kit
Old Jun 4, 2008 | 08:23 PM
Jiggly's Avatar
Default HID conversion kit
hey guys,
i found a conversion kit for my car but i was wondering, if i install the low beam and high beam bulbs, is it going 2 effect my switch inside the car 2 switch the high beam and low beam? and also the kit only comes with one like 9005 bulb i was just going 2 buy the 2 bulbs seprate will i just have 2 replace the low beam if i install the hid conversion kid on the high beam or will i have 2 put the conversion hit on both the high beam and the low beam, and the running lights, are they seprate bulbs, will i have 2 replace those also?
Thanks,
Jiggly
Old Jun 5, 2008 | 12:32 AM
jay26's Avatar
Default RE: HID conversion kit
ok first DO NOT get hids for your highs a total waste of money your lows will be plenty bright where you will not need your highs.two it is very bad on the ballast to be switching from low to high.im confused on the kit only comes with one buld huh?maybe its late and im not reading right anyways if you where to get hids for low and highs yes you will need two seperate kits again i would strongly advise no but your money.you say 9005 bulb dont know if your monte is 00-05 but the lows are 9006 and highs are 9007 i think on the highs could be wrong im tired.what i suggest is get the low kit and if you want another kit get it for your fogs if your car has them,as i did.
srbecker58
Nov 3, 2014 11:11 AM
Grounded
Oct 5, 2011 08:50 AM
03JGMonte
Oct 18, 2009 04:58 PM
srbecker58
Jun 17, 2009 11:35 PM
dutchinndj
Oct 19, 2007 10:21 AM
