help real quick
Old Nov 1, 2006 | 11:37 AM
The Black Machine 29's Avatar
Default help real quick
i know that the car im talkign about isnt a monte but maybe you can help me
my grandma has like a mid 90's lincoln continental with the 4.6 v8 and when i started it up the other day i put it into reverse and it wouldnt move unless i hit like 4,000rpms then it would move slowly... and it did the same for drive..
any ideas?
Old Nov 1, 2006 | 12:19 PM
cain45's Avatar
Default RE: help real quick
Check the fluid to see if it's low.
Old Nov 1, 2006 | 01:18 PM
fluid is fine.....
Old Nov 1, 2006 | 01:26 PM
cain45's Avatar
Was the car warmed up or cold? If cold then it may just be a flow issue in which until the fluid is warm it won't engage the transmission.
Old Nov 1, 2006 | 04:32 PM
2006MonteCarlo's Avatar
sounds like its low on fluid or the stall converter is bad or it has lack of fluid which will call the friction disc to slip and burn up
Old Nov 1, 2006 | 04:38 PM
cain45's Avatar
He said the fluid is fine.
Old Nov 1, 2006 | 04:44 PM
you cant check the torque converter fluid by the dip stick ,also if you dont check it how the dip stick tells you to it could be a bad reading, hot at ilde or cold could be either one, also a lot of people when the do maintance changing the tranny fluid they only change the pan fluid, i always have both changed it cost more and uses alot more tranny fluid but it insures you a complete transmission fluid change
Old Nov 1, 2006 | 05:19 PM
GrandPaDave's Avatar
Double A...beep...beep...M....C....O
[IMG]local://upfiles/1368/29485C06508E465B870F9FE3293C3479.gif[/IMG]
Old Nov 1, 2006 | 06:44 PM
sounds like its out of my hands then lol....
Old Nov 2, 2006 | 03:36 AM
i had aamco build my automatic for my 95 trans am drag car and it was awesome great work cost me 1900 dollars at 10% discount had it done in a couple days
