Help Finding Center Piece!!!
Old Nov 17, 2008 | 09:31 PM
BHermes21's Avatar
Default Help Finding Center Piece!!!
Ok Im sorry im not sure of the name, I have been looking all over to try and find the center console. The part that comes off with all the vents on it. Its not the actual center console but like the plastic trim that covers around the radio and the cluster. If any one know what Im looking for would be great and if you know where I could pick one up at would be even better. I scratched it during a upgrade on my car and now I cant stand seeing it. Thanks!!!
Old Nov 17, 2008 | 10:51 PM
BHermes21's Avatar
Default RE: Help Finding Center Piece!!!
By the way its for a 2004 intimidator. I think it might be called the dash trim. Sorry Im not sure what its called. But my main consurn is where can i find a new one!
Old Nov 18, 2008 | 01:47 PM
Bigg J's Avatar
I would think that you are talking about the instrument cluster dashboard shroud? Tried a local 'u-pick-a-part' type of joint?
Old Nov 18, 2008 | 06:27 PM
rj's Avatar
rj
Do you see the part you need in this illustration?
1) Instrument panel Ebony
2) Carrier
3) Ebony Ebony Right
4) Reinforcement
5) Driver side Ebony
6) Passenger side Ebony
7) Upper pad Ebony
8) Upper pad Bracket
9) Upper pad Filler
10) Black Black Right
11) Defroster vent Neutral
12) Lower plate Ebony
13) Air outlet Driver side
14) Air outlet Passenger side
15) Knee bolster Right
16) Knee bolster Left
17) Insulator Right
18) Filler Ebony
19) Control panel Heater and a/c
Old Nov 19, 2008 | 12:40 PM
Bigg J's Avatar
Cool!! Where'd you find that? I think he is talking about #5.
Old Nov 19, 2008 | 03:31 PM
BHermes21's Avatar
Thanks For the replys, and thank you RJ. Yeah its in the picture and is #5 the driver side ebony. Ill try searching for that around the net but Ive tried a pick and pull and had no luck even finding a monte carlo. So in the mean time at least I have that to go with, and by the way where did you get that pic from RJ? Its really cool and if there was pictures for other parts of the car!
Old Nov 19, 2008 | 03:36 PM
BHermes21's Avatar
And I was looking for # 13 air outlet driver side vents to. I broke one of the louvers and needs to be replaced.
smolek37k
Nov 4, 2006 04:36 AM
zipsayain
Aug 1, 2006 04:10 AM
