got hit
Old Dec 26, 2009 | 12:05 PM
silver1's Avatar
Default got hit
so a lady backed into me yesturday. only a scratch but she hit the rear driver side tire. what possible damages could happen?
Old Dec 26, 2009 | 12:22 PM
Enzo354's Avatar
STILL SLOW
Well allignment may be messed up pretty good. Check everythin under there for and bends or such. Could have messed up the wheel bearing too. *if the rear wheels have bearings idk *
Old Dec 26, 2009 | 12:25 PM
silver1's Avatar
thanks. i'm going to take it to a shop when i get some cash next week. i was driving off and let go of the steering wheel and it was still going straight. no strange noises so far
Old Dec 26, 2009 | 05:23 PM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Make sure your trailing arm isnt bent... if you have the stock ones on, they bend easily, do to GM's lacking ability to put a solid bar on in the first place lol
Old Dec 26, 2009 | 05:49 PM
RocknSS04's Avatar
Chances are your alignment is off at a minimum!
Hope for the best. Expect the worst.
I hope it's nothing but a bump.
Old Dec 26, 2009 | 06:01 PM
silver1's Avatar
thanks for the input. how much does it normally cost to just check alignment? i stay in cali and i think alot of the shops closed today. none of my sensors is on or anything either
Old Dec 26, 2009 | 06:14 PM
but when they are bent there easier to bend back than a solid bar lol i had to bend mine back into place
just look under the car on that side usually u can tell if its bent or not, unless she hit u hard u shouldnt have too much damage
Old Dec 27, 2009 | 12:36 PM
silver1's Avatar
thanks again. nothing looked out of place or damaged. again i appreciate the responses. i'm getting my brakes done so i guess i'll ask them to check see if they notice something my untrained eye didnt
Old Dec 27, 2009 | 07:03 PM
If it hit the actual wheel, I would want to check the wheel for cracks too. Probably fine. But a friend of mine's Dodge Avenger got hit and the alignment shop found cracks between the bolt holes and the center of the wheel.
Old Dec 27, 2009 | 07:48 PM
silver1's Avatar
thanks for the advice taz, i will look out for them
