Getting to the bottom of things..
Old May 19, 2011 | 07:46 PM
jwjones's Avatar
Default Getting to the bottom of things..
So I was just outside messing around with Carla some more today since I had nothing better to do and while I was pulling the dash out I noticed an issue that had occured while doing this. Okay so everyone who has done this knows that when pulling the front face of the dash out you are required to leave you key in the ignition. Well when I went to pull the dash off the key got pulled out of the ignition along with the dash because it got caught on the "Off, Acc, On, Start" cover. I immediately thought that was a little strange. As alot of you know I have been having issues with my A/C, and DIC not working sometimes and well when I went to put the dash back together I had clipped the bottom cover or, knee cover located under the dash and when I clipped it back in from under the ignition all of a sudden the A/C turned on! OMFG MAGIC! So I think I've realized that my ignition is to blame for the A/C not cooperating. What are your thoughts on this? Also if I get a new ignition from GM is there anyway I can keep the same key pattern so I am not required to have a key cut for my door and trunk and then also a key for my ignition? Or am I going to be required to have a separate key for the ignition? Thoughts please!
Old May 19, 2011 | 07:50 PM
03Monte's Avatar
i had my ignition cylinder replaced at the dealership, and i still use the same key...
Old May 19, 2011 | 07:51 PM
jwjones's Avatar
Awesome! How much did it run you to have it fixed there?
Old May 19, 2011 | 07:54 PM
03Monte's Avatar
from what i can remember...it was expensive, 300-400 ish...don't quote me on that though...
Old May 19, 2011 | 07:56 PM
jwjones's Avatar
Yikes, kinda pricey but I guess its pay the hefty bill or get it stolen!
Any other thoughts on my ignition causing my A/C not to work would be great
Thanks!
callie100
Oct 23, 2011 07:08 AM
rj
Mar 17, 2011 09:27 PM
DaneTrain
Dec 1, 2010 04:12 PM
Sciggy
Dec 18, 2007 01:35 PM
2000_BLACK_SS
Jan 14, 2007 06:12 AM
