Get in the zone!! P011
Old Aug 24, 2012 | 03:46 PM
StLBernMC's Avatar
Default Get in the zone!! P011
So I was cruising around today and the check engine light on my 06 MCLT (3.5) came on. Decided to stop by AutoZone to get the light checked. He said it came up p011 and nothing else came up. No description or anything. I'll probably stop by another one to get a second opinion and already searched the forums and didn't find anything. Wanted to see if anyone else had an issue with that code. Thanks in advance...
Old Aug 24, 2012 | 03:54 PM
Assuming that is P0110 and not P011 the intake air temperature sensor went bad, or the wiring is shot
Old Aug 24, 2012 | 04:00 PM
StLBernMC's Avatar
Yea...did a little more research and I remember this code coming up before. I meant p0011. I w ouldnt know how to fix it. Hopefully I can find someone who would be able to.
I have a 2006 Chevy Impala 3.5L. Lopes while driving. - FixYa
Old Aug 24, 2012 | 05:32 PM
When was your last oil change
Old Aug 24, 2012 | 06:22 PM
StLBernMC's Avatar
About a few weeks ago. They said i was a quart low.
Old Aug 24, 2012 | 09:23 PM
Check it now, do you know what oil was put in
Oil is the first thing you need to check with that code, could be the wrong weight
Old Aug 25, 2012 | 10:28 AM
StLBernMC's Avatar
Oh ok. Imma do that today...
Old Aug 25, 2012 | 10:42 AM
StLBernMC's Avatar
What weight do y'all use?
Old Aug 25, 2012 | 10:46 AM
I use 5w-30
Old Jan 14, 2018 | 03:07 AM
jimbobs's Avatar
I realize that this thread is 5.5 years old but it is still relevant. My 2006 3.5flex tossed this code p0011 after I continued driving it for about 3 weeks after the oil monitor told me it was time to change the oil. As you might be guessing, after an oil change and about 2 days and 125 miles the code was gone, the light was out, and I passed the IL emissions test. So it's true, even if you use the right oil much less the wrong weight oil and let it get too old/bad, it can provoke this code. I was teetering on replacing the cam position sensor or the magnet when the code went out on it's own.
Motorhead
Jun 7, 2021 05:43 PM
jackjeckel757
Apr 11, 2011 07:26 PM
Rhammah90
Aug 26, 2010 09:45 AM
Apr 9, 2010 04:17 AM
glenn
May 12, 2009 02:32 PM
