fyi
Old Sep 9, 2007 | 06:32 PM
couch's Avatar
Default fyi
working @ a GM dealership has some perks.
If you guys need a GM part number for something let me know and i'll try to look it up in a timely fashion for ya. just send me a PM on the forums.
Old Sep 9, 2007 | 06:42 PM
HyperFox's Avatar
Default RE: fyi
Nice. Just what we needed. And actually I do have a question for you. Is the MAF sensor the same on v-6 models as it is for the V8 on 06-7 models? Im thinking of upgrading the intake on the car to the K&N FIPK, but they only have a model out for the v8. If the sensors are the same, it should cross over with little modification.
Old Sep 10, 2007 | 10:20 AM
06MCLTZ's Avatar
Default RE: fyi
YEP, I HAVE THE SAME QUESTION? ALSO IS THERE ANYWAY TO BUY JUST THE MIDDLE EMBLEM ON THE STEERING WHEEL MINE IS DENTED?
Old Sep 10, 2007 | 12:56 PM
cain45's Avatar
Default RE: fyi
The emblem for the steering wheel SHOULD be able to be purchased seperately since it's just a sticker/stick on emblem.
Old Sep 10, 2007 | 01:10 PM
06MCLTZ's Avatar
Default RE: fyi
SHOULD I JUST SEE IF I CAN BUY ONE FROM THE DEALERSHIP?
Old Sep 10, 2007 | 03:32 PM
cain45's Avatar
Default RE: fyi
I would, and at least you'll know if you can get one without buying the whole steering wheel.
Old Sep 10, 2007 | 05:59 PM
GrandPaDave's Avatar
Default RE: fyi
ORIGINAL: cain45
Or at least the AirBag unit.
Old Sep 10, 2007 | 06:00 PM
Default RE: fyi
ORIGINAL: 06MCLTZ
If you figure out that it is a sticker that can just be pulled out, I have a friend that will make "Autobot" stickers that you can put on your center wheel.
Old Sep 10, 2007 | 07:25 PM
HyperFox's Avatar
Default RE: fyi
Ha. Now that would be awesome Grampa.. Count me in for one of those..
Old Sep 10, 2007 | 07:35 PM
couch's Avatar
Default RE: fyi
I'll check into the center piece for your steering wheel tommorow.
as for the MAF. it's the same on both motors (GM part number 15911983) for both 2006 and 2007 models. so you should be good. if you still have warranty check into the dealership to make sure it won't affect it. i've heard rumors that GM might be doing it.
