Wax
http://i1081.photobucket.com/albums/...406_214019.jpg http://i1081.photobucket.com/albums/...406_213145.jpg http://i1081.photobucket.com/albums/...6_213129-1.jpg http://i1081.photobucket.com/albums/...406_212926.jpg http://i1081.photobucket.com/albums/...406_212936.jpg http://i1081.photobucket.com/albums/...406_212951.jpg http://i1081.photobucket.com/albums/...406_213017.jpg http://i1081.photobucket.com/albums/...406_213029.jpg http://i1081.photobucket.com/albums/...406_213046.jpg http://i1081.photobucket.com/albums/...406_213103.jpg http://i1081.photobucket.com/albums/...406_213129.jpg http://i1081.photobucket.com/albums/...406_213214.jpg http://i1081.photobucket.com/albums/...406_213525.jpg |
Looks good man! I still really like how those headlights look. Assuming those are that second pair?
(Post 540465)
Looking clean man! I'm still waiting to afford the tags and oil and a filter until I can get mine on the road. Until then I'll enjoy my Stealth. Plus it'll give it a little more time for a few more rains to wash away the salt from the roads.
Originally Posted by BlackRainSS
(Post 540467)
(Post 540466)
thanks :thumbsup: I really like them too. Not yet. I have the second pair still sitting in my living room :rotfl: I was going to put them on tonight but decided I will keep these on for awhile til the wire wiggles loose again.....although I have noticed the high beam on the drivers side points right at the ground...idk if that can be fixed when I take it apart or not...guess you would know maybe?
I would recommend running a bead of sealant around the lens where it meets the housing, just to be safe. Out of the box, mine looked good but on closer inspection it had some small gaps here and there, mostly along the bottom edge. More apparent when I took them apart. I used that butyl rubber glue on reinstall but also ran a bead of black silicone around just to be sure it was fully sealed. Also make sure the back of the connectors are completely filled with sealant. |
(Post 540472)
Yeah, you have to adjust the aim of the reflector which is done with the hex screw (points upward) on the back of the housing.
I would recommend running a bead of sealant around the lens where it meets the housing, just to be safe. Out of the box, mine looked good but on closer inspection it had some small gaps here and there, mostly along the bottom edge. More apparent when I took them apart. I used that butyl rubber glue on reinstall but also ran a bead of black silicone around just to be sure it was fully sealed. Also make sure the back of the connectors are completely filled with sealant. I plan on taking these ones apart that are on the car at some point. The other set that is brand new I will probably run the sealant on because I dont plan on tear two sets apart if all goes well |
(Post 540476)
there is a screw for the high beams? I never saw anything. maybe I will have to look closer.
that things shiny! :D
