RE: Finally installed my k&n intake! But with problems!!
Normally if you disconnect the battery and step on the brake pedal for a couple of minutes the computer should reset.
Thanks for the insight guys.
I hear the 30 minute thing alot, but I have never had any better luck with disconnecting it for 30 minutes than I have had with doing 5.
Also if it is your brake and trac light check your brake fluid because that happened to me about a year ago because my pads were so old on my car. so maybe it was just timming that it happened when you put your new intake on.
mrl... its the only way to reset the computer on the 00 up montes... i've disconnected for 10 and did nothing.. disconnect for 30 and it will reset.
ORIGINAL: Cowboy6622 mrl... its the only way to reset the computer on the 00 up montes... i've disconnected for 10 and did nothing.. disconnect for 30 and it will reset. |
Different on the 97s? or the same. Will come in handy if I ever have to reset my computer. Havent had this car long enough but my old ford pickup was another story.
i just know when i went to auto zone once they told me to disconnect the battery for 30 mins.. never asked about the 90's models
Same here, don't know on the 5th gens. I can't see where it would hurt to do 30 min as long as you can accomplish something else while waiting.
When I have time projects like this I usually get the dishes and vacuuming out of the way while waiting. Gives me a good sence of accomplishment. :) |
