Dyno Run
Old 10-23-2007, 08:31 AM
Default RE: Dyno Run
Well, then make them buy their own credits (like 50$ for two if I remember right) and charge em to use the module.
But did the responsiveness increase? I think that should be a huge benefit of tuning the car.
Old 10-23-2007, 03:23 PM
What do they do in a dyno tune?
Old 10-23-2007, 03:50 PM
Cowboy6622's Avatar
the take off from about 0-30 didn't change a whole lot, if anything its maybe SLOWER because the tires want to burn down a bit easeir than they used to makes it easeir to burn out though. after about 30-40 mph if i'm crusing and then "floor it" it gets a lot more responsive. the guy actually used the HP Tuner, which off the top of my head, and definitly not all it could do, was this
adjust air/fuel ratio, reset shift points, adjust the timing for premium fuel, change the pressure lines on the transmission for when you are crusing and "floor it" it will down shift quicker. it made a bit of difference, and although the hp changes weren't much, it seems to have picked up a bit for getting up over about 50-60 mph as well.
Old 10-23-2007, 03:53 PM
Is it worth it? How much did it cost if you don't mind me asking?
Old 10-23-2007, 03:55 PM
Cowboy6622's Avatar
it was $350, but the handhelds are about $400 or so ,andi figured this would be better because i could see it on a dyno myself (which i had always wanted to know what it was really putting out). plus, i can come back again anytime and not pay for small changes to the tuning.
Old 10-23-2007, 03:59 PM
Cool, cool, sounds pretty good, I want to see what my car puts down also, but no dyno around here that I know of
Old 10-23-2007, 04:09 PM
Cowboy6622's Avatar
usually the power to the wheels is about 20-25% less than at the crank, so for you its probably close to 200 at the wheels.
Old 10-23-2007, 04:21 PM
Yeah I knew the hole 20-25% less thing, but just wanted to see the real number, just because
Old 10-23-2007, 04:36 PM
Cowboy6622's Avatar
haha... you sound like me when my dad asked why i was "wasting my money" on this. just becuase... lolahh, sometimes i'm just too curious for my own good.
Old 10-23-2007, 05:03 PM
Taz is offline
Duane...do you already have the U-bend delete? If you're going with a high flow cat, It would make sense to get a U-bend delete at the same time. Of course that's money permitting.
As soon as I get more of my Monte paid off, and my contract is settled at work this spring, I think I'm going to get the exhaust done.
Quick Reply: Dyno Run
