Downpipe for 3800 on 3500???
Old Dec 24, 2008 | 10:49 PM
alabamamonte's Avatar
Default Downpipe for 3800 on 3500???
Ok I have an 07 lt with a 3500 in it. So far the only performance mods ive made are a custom cai and the magnaflow catback system. I was wondering if a 3800 down pipe would fit on it? and if yes should i go with 2.5" piping or 3"? To some this might sound like a stupid question but the only reason I ask is the catback exhaust systems will inter change for these motors..
Old Dec 25, 2008 | 04:00 PM
rj's Avatar
rj
Default RE: Downpipe for 3800 on 3500???
Why do you want the 3800 pipe on your car?
If you want to remove the"U" bend pipe the '06/07 Montes came from the factory "U" bend delete.
So you've got what the 3800 guys want already.
Old Dec 25, 2008 | 05:19 PM
inssanity21's Avatar
wait i swear that when i was cleaning the salt off the underside of my car, i saw a slight ubend. im not entirely sure tho. i guess ill have to take a second look
Old Dec 25, 2008 | 08:46 PM
ORIGINAL: rj
If you want to remove the "U" bend pipe the '06/07 Montes came from the factory "U" bend delete.
Well there is a very slight one.. But thats not the reason. I thought it might add a little hp over the factory one??? Especially since you can buy one with a high flow cat..
Old Dec 26, 2008 | 04:47 PM
rj's Avatar
rj
Mine looks pretty much straight. Compared to what the 3800s got.
Check a 3800 that hasn't been swapped out yet. More then just a "Slight" bend there.
A high flow cat would be a plus in the performance department.
Old Dec 26, 2008 | 06:57 PM
drewskie043's Avatar
i was under mine the other day and yes, there is a very slight bend, but nothing that would make a huge difference. i would just leave it alone. also, i wouldn't think a 3800 downpipe would work, cuz it's a totally different engine. just my opinion though.
alabamamonte, how do you like the magnaflow catback exhaust on your 07 so far? how is the sound at idle, mid, and high rpms?
Old Dec 26, 2008 | 09:53 PM
ORIGINAL: drewskie043
It has its own distinct sound.. It doesn't sound like a four cylnder but it only sounds like a v8 at idle. When you get on it, it starts to make that distinct sound. which it is a v6 so it makes sense. It did give some noticable power gain.
If you have an 07 monte then you need to go ahead and order an 06 monte ltz driver side exhaust hanger. Since the 07 Lts only have one exit exhaust.
Overall though it was worth the money.
RattPack
16
Dec 30, 2015 04:09 PM
JrDonahue396ss
Jul 21, 2015 12:12 AM
ChibiBlackSheep
FWD Tech Guides '95-'07
20
Jan 15, 2013 09:02 PM
bumpin96monte
31
Jun 24, 2011 05:57 PM
golfstud2k4
Sep 29, 2010 03:37 PM
