5th Gen ('95-'99): Dash vents blow speraticly
Old Jun 23, 2017 | 09:19 AM
stevenjfrench's Avatar
Default Dash vents blow speraticly
Hello everyone I need a bit of help
I have a 96 monte with 3.1 L and when I turn on the vent air it blows through the floor boards sometimes but no all the time and the blower is making a whining sound when turned on.
The ac compressor is burnt up so i don't expect cold air just plain air flow in general any advice
steven french
Old Jun 23, 2017 | 09:33 AM
Smile
steven french
This could be a bearing that is going out of the Fan motor. I will check my service manuals and see if there is anything about it in there. Sometimes these things get old and wore out, if they are exposed to a dusty or Hi humidity environment.
In the event you are in an area where they have a U-pull it type salvage yard you might be able to find a functional replacement there?
Old Jun 23, 2017 | 09:39 AM
Would it just be better to replace the whole blower motor to save time?
Old Jun 23, 2017 | 08:56 PM
Smile
Sure if you can find the part and its reasonable check with Rock Auto.com or if you have a salvage yard nearby that maybe a resource too.
