crash
ORIGINAL: God_Bot
Ouch dude.
You get an estimate yet? I'd check the gaps in the body panels there to make sure they didn't get bumped.
Ouch dude.
2002 CHEV MONTE CARLO SS 6-3.8L-FI 2D CPE YELLOW INT:BLK
VIN: 2G1WX15K429319537 LIC: N POWELL FL PROD DATE: ODOMETER: 109520
AIR CONDITIONING REAR DEFOGGER TILT WHEEL
CRUISE CONTROL INTERMITTENT WIPERS KEYLESS ENTRY
STEERING WHEEL CONTROLS BODY SIDE MOLDINGS DUAL MIRRORS
CONSOLE/STORAGE OVERHEAD CONSOLE TRACTION CONTROL
FOG LAMPS REAR SPOILER CLEAR COAT PAINT
POWER STEERING POWER BRAKES POWER WINDOWS
POWER LOCKS POWER MIRRORS POWER TRUNK/TAILGATE
AM RADIO FM RADIO STEREO
CASSETTE SEARCH/SEEK ANTI-LOCK BRAKES (4)
DRIVER AIR BAG PASSENGER AIR BAG FRONT SIDE IMPACT AIR BAG
4 WHEEL DISC BRAKES COMMUNICATIONS SYSTEM CLOTH SEATS
BUCKET SEATS RECLINE/LOUNGE SEATS AUTOMATIC TRANSMISSION
OVERDRIVE ALUMINUM/ALLOY WHEELS
NO. OP. DESCRIPTION QTY EXT. PRICE LABOR PAINT
1 FRONT BUMPER
2 R&I R&I BUMPER COVER 1.8
3* R&I EMBLEM 0.3*
N 4 BLND BUMPER COVER W/O SPORT PKG. 1.3
N 5* RPR EXTENSION W/SPORT PKG. 5.0* 1.4
6 ADD FOR CLEAR COAT 0.3
02/27/2009 AT 01:59 PM 0138831700101135-01
03609 02S90U1C
ESTIMATE OF RECORD
7 FRONT LAMPS
8 R&I RT HEADLAMP ASSY 0.3
9 R&I LT HEADLAMP ASSY 0.3
10 REPL AIM HEADLAMPS 1 0.5
11 HOOD
N 12 BLND HOOD 1.5
13 FENDER
14** REPL QUAL REPL PARTS CAPA RT FENDER 1 206.00 2.5 2.0
15 ADD FOR CLEAR COAT 0.8
16 ADD FOR EDGING 0.5
17** REPL QUAL REPL PARTS RT FENDER 1 41.00* INCL.
LINER
18 DOOR
19 R&I RT BELT W'STRIP 0.3
N 20 BLND RT OUTER PANEL 1.2
21* R&I RT SIDE MOLDING 0.3*
22 R&I RT MIRROR ASSY W/O DEFOGGER 0.3
23# RE-TAPE BODY SIDE MOLDING 1 0.2
24 R&I RT HANDLE, OUTSIDE 0.3
25 R&I RT R&I TRIM PANEL 0.5
26 STRIPE TAPE
N 27* REPL RT STRIPE TAPE FENDER/DOOR 1 486.55 0.8*
28 FRONT SUSPENSION
29 REPL BLEED BRAKE SYSTEM 1 M 0.6 M
30 RT O/H SUSPENSION ONE SIDE M 3.0 M
31* REPL RT LOWER CNTRL ARM 1 165.35* MINCL.
32** REPL QUAL REPL PARTS RT AXLE ASSY 1 108.48* M 1.0 M
3.8 LITER
N 33 REPL RT HUB & BEARING W/ABS 1 296.05 MINCL.
34** REPL QUAL REPL PARTS RT STRUT W/O 1 222.18* MINCL.
SPORT
35 REPL RT KNUCKLE 1 458.77 MINCL.
36 DEDUCT FOR OVERLAP -0.5 M
37 DEDUCT FOR OVERLAP INCL.
38 DEDUCT FOR OVERLAP INCL.
39 REPL RT BRACKET SPEED SENSOR WIRE 1 9.21
40 REPL RT BRAKE HOSE 1 44.45 M 0.5 M
41# BALANCE TIRE 1 10.00 1
N 42# 4 WHEEL ALIGNMENT 1 59.95 M
43 STEERING GEAR & LINKAGE
44 REPL RT INNER TIE ROD 1 68.42 M 0.6 M
45 REPL RT OUTER TIE ROD 1 112.30 MINCL.
46 DEDUCT FOR OVERLAP -0.3
47 PILLARS, ROCKER & FLOOR
48 R&I RT ROCKER MOLDING SS MODEL 0.6
W/O SPORT PKG
49* REPL RT ROCKER MOLDING RETAINER 8 36.88*
50 WHEELS
03609 02S90U1C
ESTIMATE OF RECORD
51** REPL RECOND RT/FRONT WHEEL, ALLOY 1 179.00 M 0.3
5 SPOKE 16X6.5 (QD2)
52 OTHER CHARGES
53# E.P.C. 1 2.50
54# TOWING 1 91.00
SUBTOTALS ==> 2598.09 19.2 9.0
LINE 4 : BLEND NEEDED FOR PROPER COLOR MATCHING/CONCESSION - YELLOW NEEDS
BLENDED
LINE 5 : THIS PART IS $700+ DUE TO PACE CAR EDITION SO WE ARE REPAIRING
LINE 12 : BLEND NEEDED FOR PROPER COLOR MATCHING/CONCESSION
LINE 20 : BLEND NEEDED FOR PROPER COLOR MATCHING/CONCESSION
LINE 27 : HAD TO GO OEM AS NOT AVAIL A/M & PACE CAR EDITION
LINE 33 : RT FT SPEED SENSOR INCL IN HUB
LINE 42 : ALL NEW RT FT SUSP
ESTIMATE NOTES:
PLACE OF LOSS: INSRD STATED WAS GOING AROUND A ROUND ABOUT AND WAS
GOING TO, PAY CD: 2 DI: DM: 49 CO: 13 NI: 1 LDC: 506 SYM: CO
L TOWED: YINST:AIRBAG INFLT: N LH: INC
PT DT: 11 18 99RR: 0750 MBI: UMPD:;
CHECK# SYS GEN
TOW BILL ATTACHED? YES
RENTAL DISCUSSED? YES
IF NO D/L OR REGISTRATION, EXPLAIN: TOWED IN
LKQ, A/M, REMAN AVAILABLE: TRIED LKQ CORP/GAGEL'S/GREENLEAF
CUST CONTACTED BEFORE & AFTER ESTIMATE
PRIOR DAMAGE NOTES:
DIRECT HAS OTHER CLM
PARTS 2504.59
PARTS DISCOUNT $ 1677.98 -10.0% -167.80
BODY LABOR 14.0 HRS @$ 40.00/HR 560.00
PAINT LABOR 9.0 HRS @$ 40.00/HR 360.00
MECHANICAL LABOR 5.2 HRS @$ 55.00/HR 286.00
PAINT SUPPLIES 9.0 HRS @$ 22.00/HR 198.00
OTHER CHARGES 93.50
SUBTOTAL $ 3834.29
SALES TAX TIER 1 $ 3743.29 @ 6.5000% 243.31
03609 02S90U1C
ESTIMATE OF RECORD
TOTAL COST OF REPAIRS $ 4077.60
ADJUSTMENTS:
DEDUCTIBLE 250.00
TOTAL ADJUSTMENTS $ 250.00
NET COST OF REPAIRS $ 3827.60
1 FRONT BUMPER
3* R&I EMBLEM 0.3*
03609 02S90U1C
ESTIMATE OF RECORD
7 FRONT LAMPS
11 HOOD
N 12 BLND HOOD 1.5
13 FENDER
LINER
18 DOOR
26 STRIPE TAPE
28 FRONT SUSPENSION
3.8 LITER
SPORT
W/O SPORT PKG
50 WHEELS
03609 02S90U1C
ESTIMATE OF RECORD
52 OTHER CHARGES
53# E.P.C. 1 2.50
54# TOWING 1 91.00
BLENDED
ESTIMATE NOTES:
CHECK# SYS GEN
PRIOR DAMAGE NOTES:
PARTS 2504.59
OTHER CHARGES 93.50
SUBTOTAL $ 3834.29
03609 02S90U1C
ESTIMATE OF RECORD
ADJUSTMENTS:
DEDUCTIBLE 250.00
It's actually kind of a good thing, if you check the picture out in my signature you can see that i had a little pre-existing damanage to the right front (the bumper extension isn't flush properly) and the right front fender was buckled a little bit (though for the most part that was hidden by the checkered flags). I was going to have to have to replace all that myself anyway, and this way all I pay is the $250 deductible, and as long as my insurance rates don't go up too much I should come out on top
oh man that is rough!!! are you also getting the "small ding" repaired from when the guy backed into it too? that really sucks man, i hate it for you. best of luck on all the repairs, i hope you are able to get it fixed better than new!!
i used to drive a 99 corolla before i got my monte, and it was pretty trashed. i never cared about little dings because it was so f'd up that you'd never notice a new scratch. now that i have a "nice car" though, i can certainly understand how much it sucks when something like that happens. you'll have to keep us updated on the repair status.
yeah i'm getting that dinged taken care of as well, the car is obviously in the shop now so it looks like i'll never be able to get a picture of the damage. The same body shop is fixing both accidents. A bit of humor in that I'll probably be getting a second rental car as both accidents require more then a days worth of work and the insurance company is required to provide a car. Obviously I'll just stick with the one rental I got now (an 08 Impala that is pretty nice and has me wanting to figure out how to install remote start in my monte) and pocket the cash on the other.
haha there you go. not a bad deal.
side, if you figure out the remote start let me know. that's something i've wanted forever and with the -3 degree weather lately, i can't stand going outside with the car cold!! thank god the heated seats are super quick!
