crank case breather
Old Jan 23, 2011 | 08:08 PM
augi's Avatar
Default crank case breather
I have seen many newer montes with a breather filter in place of their oil cap. In consideration of doing this to my own car, what are the gains, pros, cons, and the prerequisites to this?
Old Jan 23, 2011 | 08:20 PM
from an earlier post by chibi Mike....
You should just put the regular oil cap back on your car and just use the breather for shows. That breather is only for people that need to disable the PCV system because of something like an intercooler. Your PCV will vent your crankcase enough and better than that.
You are doing more harm than good Your oil cap and dipstick are sealed off for a reason
Old Jan 23, 2011 | 08:30 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
What does the oil filler cap have to do with the intercooler? I have no clue. I know that my "old" pcv system vents to atmosphere, but I don't know why... I am really curious. I'm not posting this to be contrary.
Old Jan 23, 2011 | 08:35 PM
Greg, just something I remember reading here....I'm also not trying to be contrary either....
Old Jan 24, 2011 | 10:08 AM
If you need to have a vent for your crankcase because you had to disable your PCV system, then you should run the filter oil cap.
If you want to have it, just because you think it looks cool but still have a functioning PCV system, then you aren't helping.
Old Jan 25, 2011 | 10:08 PM
nitehawkjcb's Avatar
Originally Posted by chibiblacksheep
if you need to have a vent for your crankcase because you had to disable your pcv system, then you should run the filter oil cap.
If you want to have it, just because you think it looks cool but still have a functioning pcv system, then you aren't helping.
thissssss
Old Jan 26, 2011 | 07:19 AM
augi's Avatar
And this is why I posted on this subject. I didn't know if it would help or strictly for show.
How would running an intercooler be any different on whether its needed or not
Old Jan 27, 2011 | 11:47 AM
Because you have to disable the PCV system in your engine in order to run one most of the time.
Old Jan 28, 2011 | 03:59 AM
biggriggs's Avatar
It doesn't. A breather would usually take the place of the oil filler cap, as it allows a direct vent to the crankcase in a car that doesn't have a working pcv system.
For the OP, there is no benefit to this unless you're going turbo (in which case the benefit is the turbo lol, and there just isn't a way around the breather otherwise), and on a stock n/a car could end up making your car run worse (you'd be creating a vacuum leak essentially).
Not really. Of the three vendors that are currently selling L67/L32 intercoolers, the ZZP and PRJ have full stock pcv function. The W-body store core doesn't retain full pcv function, but it does retain the vacuum source from the rear head. It only blocks off the fresh air source going into the front head. I guess a few of the older cores had a setup similar to the WBS core, but I wouldn't say most.
Also for an intercooler core that blocks off the front stock pcv passages (like the WBS one), you're better off routing metered air into the valve cover instead of running a breather. I guess this can be a little tricky with a stock L67 throttlebody, but is really easy with a northstar or LS1 throttlebody setup.
Old Jan 28, 2011 | 07:35 AM
Thanks biggriggs. Great info.
