Center Console removal
Old Jun 8, 2010 | 06:16 PM
blackbeauty89's Avatar
Default Center Console removal
how do you go about removing the center console on 6th gen montes? some how mine is wacked up now and the bottom isn't flush with the top anymore so i want to take it out and see what the deal is.
Old Jun 8, 2010 | 06:22 PM
lucian*91's Avatar
sounds crazy, but they snap off. they have clips that you apply a little pressre againt and they come out
Old Jun 8, 2010 | 08:14 PM
04MonteLS's Avatar
That's not how mine comes out. I have a couple screws I gotta remove. One is in the cubbie area under the a/c controls, there should be a rubber mat that lines the bottom of the cubbin area, pull that out and you'll see the screw i'm talking about. Then I also have a couple screws inside the armrest that have to come out as well. Once those are out then I can manipulate the console to come out, making sure to unplug the traction button and cig lighter. You also might have to put the key in the ignition and put the car in the lowest gear in order to get it over the gear shifter.
You can take just the top part off though, the part that goes around the gear shifter, that's the part that's held in with clips, IIRC.
Old Jun 8, 2010 | 08:28 PM
lucian*91's Avatar
yeah, i forgot about the screw under the mat. but the others shouldnt be necisary, sounds like the top just needs to be snapped up and back down. mine want flush where the seatbelt is. i opened the armrest, popped out the little heated seats plastic, then pulled up on the top piece, realined it, and snapped it back on
Old Feb 15, 2013 | 02:43 PM
shynativegrl's Avatar
This thread has been out for awhile. the top portion of my center console is broken near the cup holder. I currently have an ugly tape job on it right now. Is there somewhere I can get the top part?
Old Feb 15, 2013 | 02:48 PM
remove the screw like they stated and pull up on it and it'll come out
Old Feb 15, 2013 | 04:24 PM
I watched your video and I know I can get it out but its broken where can I get new one at?
Old Feb 15, 2013 | 04:46 PM
what exactly is broken? The dash or the center council? I would get one at the junk yard
Old Feb 15, 2013 | 05:22 PM
The top part of the center console is broken into two pieces across the cup holder. Where did you get your replacement parts for your dash wen you swaped youe dash out?
Old Feb 15, 2013 | 05:33 PM
I never swapped my dash out, but like I said, I would recommend going to the junk yard. That's probably where you'll find one the cheapest
