Another Bad Transmission
Old May 19, 2017 | 03:11 PM
user 35764368's Avatar
Usually a rebuilt just have the worn out components replaced... a reman typically has had many more components replaced and will have a much longer warranty....but of course price will be higher.
Old May 20, 2017 | 10:37 PM
claydoh's Avatar
I had mine done almost exactly a year ago, it was acting up so I took it to my regular mechanic shop. I had them do a filter/fluid service first, (not a flush), to see if that would do it since I never had done that but it did not. they did the rebuild plus while it was out replaced the rear oil seal, oil pressure switch and the oil pan gasket all for $1700, plus the monet I spent first for the filter/fluid change, but 1 year later still driving great! think I got a great deal, good shop, fair and honest people
Old May 25, 2017 | 03:54 AM
96z34man's Avatar
It should have never had the 4t65e-HD. GM knew that the trans topped out at 300hp, and definitely should have mated these cars to the 4L80E
Yet, when I asked if I should replace my 65 with the 80 here, you would've thought I was a pedophile given the reactions.
I agree with the "follow the money" people, though. The 80 went into the lower-volume cars, which went to the older drivers who were less likely to incinerate their tires at every green light.
I'm one, which may explain why I had no problems with the 65 in my GTP, and only two in this car, one of which was solved by adding fluid, and one of which was caused by a misfire.
Old May 25, 2017 | 08:52 AM
It's just too much custom work to go through that process to mate it, as opposed to getting the 4t65e built.
I just wish GM did it from the start
Old May 25, 2017 | 07:19 PM
S.O.G.'s Avatar
Just got my car back from transmission shop and the guy told me he installed transgo shift kit AND superior shift kit. I didn't know you could do 2 different type at once? Anyone think it's good or bad?
