99 monte starts when jumped but dies when truned off
Old Jan 19, 2014 | 11:36 PM
Brandon Wohler's Avatar
Default 99 monte starts when jumped but dies when truned off
i have a 99 monte and it starts and runs just fine when jumped but no matter how long i drive it or let the alternator charge it...it wont start when i turn it off...i put some leds in it and used to small guage wire and it started to smolder but i turned it off right away...i have no idea what to do any info will help thanks
Old Jan 19, 2014 | 11:47 PM
l67ss's Avatar
Check ur battery and all grounds
Old Jan 19, 2014 | 11:57 PM
im going to check the battery tomaro but im just wondering if using that small gadge wire coulda melted a ground wire some where...where to u think i should start first with that?
Old Jan 20, 2014 | 08:56 AM
You definitely have a short somewhere in the system. It's. Also quite possible you have a failing diode in the alternator.
It doesn't take much "smoldering" to really short out the electrical system on these vehicles.
How old is the battery? Quite possibly it's time for a replacement as well. GM has built in a safety system ..that when the charge gets below a determined voltage it shuts down the ability to keep cranking it til the battery is dead. Thus not overheating the wireing.starter etc..
Batterys generally only have a 3 yr shelf live..Sometimes you may get 5 yrs out of a battery.. but that rarely happens.
montygrey01
Nov 7, 2014 08:19 PM
Ranceit
Apr 24, 2013 10:55 AM
SgtWyatt
Mar 12, 2012 09:44 AM
dirty mech
Jul 24, 2010 01:17 AM
fedspunisher
Apr 5, 2007 09:55 PM
